Tom123
Bosch SHU33 dishwasher stuck on drain cycle?
5 posts in this topic
Hello everyone,
I bought the wife a second hand Bosch SHU 33 dishwasher. At first it was not getting enough water and not cleaning the dishes well. There was also residue soap still leaking from the dispenser after the wash cycle. I since cleaned the filters inside the machine and at the water connect valve and found debris in both of them. Now the machine seems to be stuck in drain mode and doesn't proceed further. I posted a brief 1 minute vid below of the machine and the sound it makes for your review. TIA for any help.
http://www.youtube.com/watch?v=ePv5H2BaHFU
Regards,
Tom
The flood switch is engaged....the float your pointed to in your video is for the flood switch...follow that red actuator up and see if it is depressing the switch or if maybe the switch is stuck
Thank you for all the help. I checked the switch and made it move freely. The washer runs perfectly now. Thank You again.
Regards,
Tom
Good job, tom. If that switch gets stuck again, you may end up replacing it.
