Whirlpool washer LA9500XTWO slow agitator and grinding sound
#1
Posted 21 March 2011 - 09:37 AM
I'm new to this forum so any and all help will be greatly appreciated. We have a about 15 year old washer Whirlpool la9500xtwo 3 speed 9 cycle, additional info on the tag stock number LA9500T. About 3 months ago i replaced the motor coupling Item # 1195967 . a few days ago my wife said the washer was making a grinding sound so i came to this forum and learned about these dog ears which all 4 were broken. i replaced them this morning with the Agitator repair kit item # 3109 . Here is where i'm at. everything works the machine fills up then it starts agitating stops after a few minutes the goes to the 2nd cycle which agitates. Here is where this problem is driving me mad. its this part of the cycle which the grinding sound and the very slow moving agitator are happening. no other problems happen during the rest of the normal cycle i have not been able to find this issue on the net so i ask all of you for any suggestions or help with this issue. Thank you in advance for any help
Dan Glazewski
#2
Posted 21 March 2011 - 09:50 AM
The slow & grinding is only during the second Agitate Cycle ?
YouTube video ?
#3
Posted 21 March 2011 - 10:15 AM
(no grinding) ? No Grinding
The slow & grinding is only during the second Agitate Cycle ? YES
I will see if after work i can post a video to youtube showing the slow speed and grinding later on tonight
Thank you for the quick response
Dan Glazewski
#4
Posted 21 March 2011 - 10:51 AM
1) Agitates High
2) Agitates Low
Try it in the Knits / Gentle Wash Cycle sequence
1) Agitates Low
2) Agitates Extra Low
#5
Posted 22 March 2011 - 07:37 PM
This video is only about 2 minutes, we ran this cycle on the perm press and the grinding happened on about 4 cycles, we normally run it on heavy or normal and the only cycle that was clicking and grinding was the 2nd agitation cycle. thank you in advance
Dan Glazewski
#6
Posted 23 March 2011 - 12:35 AM
#7
Posted 23 March 2011 - 01:49 AM
is it "bad" in the 1st and 2nd Agitate Cycle ?Try it in the Knits / Gentle Wash Cycle sequence
1) Agitates Low
#8
Posted 23 March 2011 - 06:07 AM
Edited by nickfixit, 23 March 2011 - 06:09 AM.
#9
Posted 23 March 2011 - 04:23 PM
recheck the motor harness connections, make sure the harness is fully seated. Some machines had an extra 2 wire harness connection that can work loose, these were 3 speed motors.
Yep - I'll bet ya Nick nailed it, I recall those little pigtails being forgotten about when reconnecting the Motor and causing that very issue - Good Call !
