Asko 1385 Dishwasher doesn't work through cycle
9 replies to this topic
#1 momfxit
momfxit
    Ikkō-ikki
  • 30 posts
Posted 24 March 2011 - 05:28 PM
My 1385 dishwasher will fill with water, then stops. I move it to the wash cycle and it will wash and not advance. I just read another post that the dishwasher's water needs to heat to a certain temperature for the timer to advance. How do I know if the heating element is working properly?
Mom
#2 certified tech group 51
  • 1,972 posts
Posted 24 March 2011 - 09:29 PM
Is there a different model number on the unit ?? Brand ?? or is it a Asko perhaps?? :blush: P.S. did you read the post on your surface switch question???
Edited by certified tech group 51, 24 March 2011 - 09:31 PM.
#3 momfxit
momfxit
    Ikkō-ikki
  • 30 posts
Posted 25 March 2011 - 08:26 AM
I did read the post and have found the part. :thanks:
This dishwasher is an ASKO 1385. I've put in several new switches. The last set of switches went in (that should have been covered by recall and weren't) ended with the timer not advancing. :unsure: :wallbash: I know the timer is not the issue--ordered another one and it's doing the same thing. Something is causing the timer not to advance. I crawled under the dishwasher this morning and tested the element and it tested fine. However, there is no heat...I'm patient and will get this system to work, just need some guidance.
#4 certified tech group 51
  • 1,972 posts
Posted 25 March 2011 - 08:28 PM
cannot find a wire diagram for that model number, :confused: Do you have one that came with the unit?? maybe post it?? :thumbsup: the element is ether good or bad, check the continuity. If continuity=good / no continuity=no good........look for a thermostat, that will tell the computer/clock when to advance.........possibly a small round disc attached to the bottom of the tub.........
#5 momfxit
momfxit
    Ikkō-ikki
  • 30 posts
Posted 26 March 2011 - 10:42 AM
Reg set me a schema...if it is the thermostat, i'd be happy to try.
http://appliantology...__1#entry190050
I've a parts diagram, but it's too large to attach.
Edited by momfxit, 26 March 2011 - 10:45 AM.
#6 RegUS_PatOff
  • 30,200 posts
Posted 26 March 2011 - 01:17 PM
9 Topics posted in the last 6 months . . .
looks like you're having good luck with that Asko :woot:
#7 momfxit
momfxit
    Ikkō-ikki
  • 30 posts
Posted 27 March 2011 - 09:40 AM
yeh, yeh, you wait...I started chewing on the corporates on Friday. My husband says I will not get any where with them. But you guys just wait... :starwars:
You're better off working WITH Mom than refusing to HELP Mom!
I've taken on Nissan and another corporate giant and received satisfaction.
I'm taking on Asko. You just wait Sensei :ninja:
Edited by momfxit, 27 March 2011 - 09:43 AM.
#8 certified tech group 51
  • 1,972 posts
Posted 27 March 2011 - 10:52 AM
RegUS could you P.M. little ol' me a copy of the schematic you sent momfixit?? :thanks: ...................... Do not want to get on the bad side of momfixit :woot:
#9 RegUS_PatOff
  • 30,200 posts
Posted 27 March 2011 - 12:44 PM
it's posted as a .JPG in the "Wiring Diagram" post
http://appliantology...ivity&mid=53780
  • 24,217 posts
Posted 28 March 2011 - 08:23 PM
Here's the direct link to the post with the wiring diagram.
