LG DLE7177RM electric dryer Not Heating
#1
Posted 25 March 2011 - 11:57 AM
I checked and it is getting 240 volts and I followed the tests in the service manual but to the best of my ability I can't find what's wrong with it.
I figured it's probably one of two things:
1) I just got a bad heating element that died after a week
2) Something else is blowing the heating element.
The one thing that didn't match with the service manual is that the resistance across terminals 2 and 3 is 40 ohms and not less than 9-11. However, it was like this when I got the new heating element before I installed it. I chalked this up to human error and it being almost 20 years since I used a multimeter in physics class. Also, the thermostat in the middle is reading 0 ohms and the one closest to the back is reading a really low resistance. The manual says that they should both be under 1 ohm, but should the one be 0?
#2
Posted 25 March 2011 - 12:01 PM
#3
Posted 25 March 2011 - 12:41 PM
1) Human error, yes, the manual should read:... The one thing that didn't match with the service manual is that the resistance across terminals 2 and 3 is 40 ohms and not less than 9-11.
... the thermostat in the middle is reading 0 ohms and the one closest to the back is reading a really low resistance.
1 - 2 should read about 20 OHMs
1 - 3 should read about 20 OHMs
2 - 3 should read about 40 OHMs
2) in my physics class, 0 is less than 1 OHM ...
in theory, any closed switch or fuse should read 0 OHMs
There's (3) Thermostats (one on the Blower Housing)
#4
Posted 25 March 2011 - 12:54 PM
#5
Posted 25 March 2011 - 01:10 PM
never mind, that Thermostat would stop the Drum MotorThanks. I didn't check the one on the blower housing.
#6
Posted 25 March 2011 - 11:55 PM
Oh, and the reason I questioned the 0 reading is because my multimeter also reads 0 if you don't touch anything. Now that I'm more awake and more with-it I double checked by also checking for continuity.
#7
Posted 26 March 2011 - 01:14 AM
Unless-----the *exhaust vent* from the rear of the dryer-to-the-outside-venthood is/has been blocked/restricted for a very,very long time.
Even then---the Heating Element usually does not fail.
I've replaced perhaps **one** Heating Element in nine years.
On the other hand---THERMAL LIMITERS will & do fail if the *exhaust vent* is blocked/restricted.
If the *exhaust vent* is a very short-length (1 to 3 feet)---then the liklihood of the vent causing a failed THERMAL LIMITER is nil. The 2nd most common cause of *failed* THERMAL LIMITERS is from Fabric Softener Sheets. Once-in-awhile the Fab. Soft. Sheet will become "caught/sucked" onto the LINT FILTER HOUSING and this causes a giant reduction in AIR FLOW.
Air movement from the Heater-Through-The-Laundry-Through-The-Lint-Filter-And-Exiting-The-Dryer-Exhaust-Vent slows to such a reduced a level---which then causes the Heater Housing Temperature to "spike". This in turn causes the THERMAL LIMITER to *shut-down* the Heater--for safety.
When I get an LG electric dryer that has a NO HEAT complaint--the very first thing that I will examine/rule-out will be the *exhaust venting* that runs from behind the dryer to the outside dryer vent hood. If the vent has been verified 100% to be absolutely-positively clear/unobstructed---and...
1) The wall receptacle has 220 volts
***Unplug the Dryer at this point***
2) The TERMINAL BLOCK is not damaged/burnt (this is where the dryer plug attaches to the dryer)
Then it's time to inspect the THERMAL FUSE. This is centrally-mounted on the side of the HEATER HOUSING.
If the THERMAL FUSE (6931EL3003D) has failed a *continuity* test using a Digital MultiMeter (DMM)--it should be replaced along with the THERMOSTAT (6931EL3001E) which is also mounted on the HEATER HOUSING.
If the THERMAL LIMITER tested "good"...
Place the test leads into the Motor Connector/Plug. One test probe into each of the two *thickest* wires of the Motor Plug.
Looking at the Motor---you'll notice a *black ring* on the motor shaft directly opposite the Motor PULLEY.
This *black ring* is part of the CENTRIFUGAL SWITCH on the Motor (prevents the Heater from functioning if the Motor fails to start).
Use your finger to slide the *black ring* towards/in the direction of the BLOWER WHEEL (it'll slide about 1/2 inch).
At this point the DMM should show *continuity*. If not--replace the MOTOR.
If the CENTRIFUGAL SWITCH tests good---replace the MAIN BOARD (a rare failure for a NO HEAT condition but not impossible).
Edited by john63, 26 March 2011 - 10:04 AM.
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#8
Posted 26 March 2011 - 03:45 AM
are the probes touching each other ?... my multimeter also reads 0 if you don't touch anything
... closed circuit / closed switch / closed Fuse ...
#9
Posted 26 March 2011 - 11:36 AM
HEATING ELEMENTS in LG dryers **rarely** fail.
I think the vent was blocked originally, I was blowing it out with a leaf blower and at one point there was a significant change of pressure. As of right now there's a very obvious air flow from the outside. Also during the whole process I went through the vent system within the dryer and it's now clear. There wasn't anything blocking it but there was quite a build up of lint.
Well I already replaced the heating element and then it worked for about a week. The new thermal fuse did fail the continuity test now that the dryer stopped working. So I'm wondering what might be the problem if nothing is blocked, but the thermostat died again? Or did I just get a bad heating element?
#10
Posted 26 March 2011 - 01:28 PM
... The new thermal fuse did fail the continuity test now that the dryer stopped working.
usually an indication of a Vent problem
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
Troubleshooting tips for LG electric dryers that won't heat
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 26 March 2011 - 04:54 AMHEATING ELEMENTS in...
Read Full Entry →
