Whirlpool DU1145XTPQA Quiet Partner II Dishwasher Not starting
#1
Posted 25 March 2011 - 03:49 PM
When I hit the Cancel button, the dishwasher runs through the drain cycle, but when I hit the Start button, nothing happens. There are no lights flashing on the control panel.
I took the control panel out and inspected for burnt spots on the circuit board, but found none.
Are there any other common issues that I can check for?
Drew
#2
Posted 25 March 2011 - 04:23 PM
Servicing Southern Manitoba, Canada
#3
Posted 25 March 2011 - 05:19 PM
Another thing, when I press Normal in the Cycles section of the control pad, the LED above the button does not light up. I have removed the control panel again and gone through it looking for anything that looks odd, but haven't seen anything yet.
Is the thermal fuse the small round component that has 2 wires and clips onto the chassis of the control board? I have read elsewhere that I would need to check the continuity of the thermal fuse, but I am not sure where it is.
Drew
Also, the float is clicking when I pull it up and let it fall, so I assume the float switch is working properly.
Drew
#4
Posted 25 March 2011 - 05:22 PM
#5
Posted 25 March 2011 - 05:56 PM
KEY . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .+Pos. Lead – Neg. Lead
DELAY HOURS . . . . . . . . . . . . . . . . . . . . . . . . . . . P1-12 . . . . P1-2
SMART WASH/ACCUSENSE/ ADAPTIVE WASH . . P1-13 . . . . P1-2
SOAK & SCOUR/STEAM/STEAM SANI . . . . . . . . . P1-11 . . . . P1-3
CANCEL/DRAIN . . . . . . . . . . . . . . . . . . . . .. . . . . .P1-12 . . . . P1-3
POTS & PANS/HEAVY. . . . . . . . . . . . . . . .. . . . . . P1-13 . . . . P1-3
HIGH TEMP. . . . . . . . . . . . . . . . . . . . . . . . . . . .. .. P1-11 . . . . P1-4
START/RESUME. . . . . . . . . . . . . . . . . . . . . . . . . . P1-12 . . . . P1-4
NORMAL WASH/NORMAL. . . . . . . . . . . . . . . .. . . P1-13 . . . . P1-4
SANI RINSE. . . . . . . . . . . . . . . . . . . . . . . . . . . .. . P1-11 . . . . P1-5
TURBO/PRO SCRUB/POWER SCOUR. . . . . . . . . . P1-12 . . . . P1-5
CHINA/LIGHT. . . . . . . . . . . . . . . . . . . . . . . . .. . . . . P1-13 . . . . P1-5
HEATED DRY. . . . . . . . . . . . . . . . . . . . . . . . . . . . . P1-11 . . . . P1-6
RINSE ONLY/QUICK RINSE. . . . . . . . . . . .. . . . .. . . P1-12 . . . . P1-6
GLASS XPRESS/FAST WASH/ QUICK CLEANUP . . P1-13 . . . . P1-6
#6
Posted 28 March 2011 - 01:56 PM
Drew
#7
Posted 28 March 2011 - 02:10 PM
#8
Posted 28 March 2011 - 02:29 PM
Just to be sure, I connected the old panel to the new board... no go... so I guess the control board is good. Now I can't find the correct part on the list of parts, which category is it under?
Drew
By panel, I mean the control panel on the top of the dishwasher, the part with the buttons.
Drew
#9
Posted 28 March 2011 - 05:15 PM
The only issue I had while removing the button cover was the bottom right side, the white background of the plastic tore off and stayed glued to the hard plastic. This doesn't look too bad, and since the machine works, it doesn't matter to me!
Thanks for all the help,
Drew
