Admiral dryer AED4475TQ1, won't heat
#1
Posted 27 March 2011 - 08:03 PM
#2
Posted 27 March 2011 - 08:08 PM
Does anyone know the model number ?.Does anyone know what the problem could be?
#3
Posted 27 March 2011 - 08:13 PM
#4
Posted 27 March 2011 - 08:57 PM
1) shut OFF before the Timer timed-out ? (may be bad Drum Motor)... most of the time it would shut off
... it would not start back up unless i had the timer set on air dry or cool.If i set it on any heat setting it will not run
.... heat coils.3 of the coils were all black.
2) may be bad Timer
3) there's only one continuous Heater coil
check and re-set your House Circuit Breakers for the Dryer
check for 240v Ac at the Dryer Cord Terminal Strip
#5
Posted 28 March 2011 - 04:20 AM
#6
Posted 28 March 2011 - 05:21 AM
... no... timer off and noticed that it makes a rattly noise like something is broken inside.Is this normal
#7
Posted 28 March 2011 - 06:14 AM
#8
Posted 28 March 2011 - 06:22 AM
So you think the timer could be the problem?? Thanks!
yes, if there's something rattling inside
Any part ordered from RepairClinic can be returned in original condition
within 30 days for a refund (less shipping).
http://www.repaircli...R=154&N=1481701
#9
Posted 28 March 2011 - 06:39 AM
#10
Posted 28 March 2011 - 06:45 AM
#11
Posted 28 March 2011 - 10:22 AM
#12
Posted 28 March 2011 - 01:15 PM
www.eliteapplianceservice.org
#13
Posted 29 March 2011 - 05:41 AM
#14
Posted 29 March 2011 - 07:00 AM
No, you cannot buy the switch, you have to buy the entire motor.
#15
Posted 29 March 2011 - 08:25 PM
