skywalker
Whirlpool gas dryer GEW9200LW0 slow to dry clothes
6 posts in this topic
I have a Wirlpool front loader model# GEW9200LW0. I stop drying my cloths. I don't understand the dryer gets hot but the cloths are still wet even after putting it on timed dry for 99 min. I've opened it up to clean out all the lint that was in the compartment even in the back of the dryer.
try a load with the Vent disconnected
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
I disconnected the vent hose from the back of the dryer. I set it for 60min. at high temp and the close are still a little damp. I don't have access to a a temp gauge so I could not check the temp. Where the vent exits the apartment I used a vent clean out tool that brushes the vent line. I must have brushed and vacuumed out 12ft. out-going and 12ft. incoming. The total length from laundry room to outside vent is approx. 25-26ft. I'm confused about this.
But the clothes were much dryer at the end of the dry cycle with the vent off vs. with the vent on, correctum? This would point to a problem in the vent. See the Ultimate Dryer Venting Guide for lots o' good poop on this.
... I don't have access to a a temp gauge.
a meat thermometer would work.
Would need temperatures to diagnose. . .
Thanks guys!! And yes the cloths are drying now. It takes about two 60 min.cycles but the cloths are drying. And I'll pick up a thermometer tomorrow. This is the greatest site. COOL!!!
