Whilpool Duet 9150 error code "du F" door locked - won't open!
4 replies to this topic
#1 davidos
davidos
  • 13 posts
Posted 19 October 2005 - 07:44 AM
Can't get Washer door open on Duet 9150.... Little over a year old.... code is 'du F'.
How can I get my laundry out and fix this? Thanks!
#2 Pegi
Pegi
  • 13,120 posts
Posted 19 October 2005 - 11:56 AM
Here you go, your new reading material, job aid for the Duet Washer...
#3 davidos
davidos
  • 13 posts
Posted 19 October 2005 - 12:34 PM
THANK YOU....!  worked like a charm.... got the door open and my musty laundry is FREE... now to replace the door lock... is there a good place to order parts?
Do you have any 'reading material' for the F&P GWL11 that I have at home?
Thanks again!
#4 Pegi
Pegi
  • 13,120 posts
Posted 19 October 2005 - 12:38 PM
Can order the switch right here from this site, use the handy forms right at the bottom of this page, helps support the site, ya know.  Will see if I can find something on the F&P.  ;)
#5 Pegi
Pegi
  • 13,120 posts
Posted 19 October 2005 - 12:43 PM
This is all I could find right now, perhaps someone else has access to a repair manual that is not on a protected server like STH.
