davidos
Whilpool Duet 9150 error code "du F" door locked - won't open!
5 posts in this topic
Can't get Washer door open on Duet 9150.... Little over a year old.... code is 'du F'.
How can I get my laundry out and fix this? Thanks!
THANK YOU....!  worked like a charm.... got the door open and my musty laundry is FREE... now to replace the door lock... is there a good place to order parts?
Do you have any 'reading material' for the F&P GWL11 that I have at home?
Thanks again!
Can order the switch right here from this site, use the handy forms right at the bottom of this page, helps support the site, ya know.  Will see if I can find something on the F&P.  ;)
This is all I could find right now, perhaps someone else has access to a repair manual that is not on a protected server like STH.
