Sign in to follow this
Followers 0
B64
Jenn-Air JDB1100AWS dishwasher - water left in basin after cycle
2 posts in this topic
Looking for some advice with my Jenn-Air dishwasher JDB110AWS.
The issue is that there is water left in the bottom after the cycle completes.
Installation is correct, the Drain hose is clear and free flowing as is the garbage disposal and sink.
I have tested the pump and it is working. I tested the float switch and it is good but when manually tripped it
does not kill the pump. Could this be something to look into or does does the float switch only pertain to the filling cycle?
Is there a self diagnostic mode I can put it through?
Any direction or things to chase would be much appreciated.
JDB110AWS
maybe
JDB1100AWS ?
Float Switch only controls the Water Valve
Field Service Test
A Field Service Test may be started by pressing the key 5 times followed by the key within 6 seconds.
This test must be performed with clean water to insure proper sensor performance.
“88” will appear in the display (if available*) and the following sequence of events will occur:
SECONDS . . . . . FUNCTIONS / ACTIVE LOADS
106 . . . . . . . . . . .Water Valve
5 . . . . . . . .. . . . .Thermistor check / Turbidity Sensor check & Calibration - no loads active.
120 . . . . . .. . . . . Wash Motor / Dispenser Wax Motor
180 . . . . . . . . . . .Wash Motor / Heater
120 . . . . . .. . . . . Drain Pump
4 . . . . . . . . . . . . .Water Valve
For manuals and lots of other goodies,
become an Apprentice==> http://appliantology.org/apprentice/
Followers 0
