Frigidaire FDE647RFS1 dryer wont start
8 replies to this topic
#1 pedals
pedals
  • 4 posts
Posted 03 April 2011 - 06:08 PM
I have a fridgidaire dryer mod #FDEC647RFS1, it was working fine yestaurday today I went to start it and got nothing, When i turn the start nob i just hear a click coming from the timer area and then just quite little ticks coming from the timer thats it, it doesn't start up at all or anything. any idea on what could be the problem...thank you
#2 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 03 April 2011 - 06:24 PM
Most likely a fuse.
Can You Check that model # again?
#3 pedals
pedals
  • 4 posts
Posted 03 April 2011 - 06:35 PM
thats the model number showing on the side of the doorway
#4 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 03 April 2011 - 06:40 PM
are you in Canada?
#5 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 03 April 2011 - 06:58 PM
I figured it out, there shouldn't be a "C" in the model #
Take a look at the fuse linked here
Fuse Link
Pop the top up on the dryer (with it unplugged)
The fuse is attached to the right rear wall of the dryer
right beside the terminal block (where the cord attaches)
unplug the wires from the fuse and check continuity
no continuity = bad...and if so check your venting
for a crimp or restriction as well as the lint filter housing,
it tends to clog up at the bottom.
correct the problem before replacing the fuse (if it's bad)
or it will blow again.
#6 pedals
pedals
  • 4 posts
Posted 03 April 2011 - 07:54 PM
tks i'll try that tommorow after work
#7 pedals
pedals
  • 4 posts
Posted 04 April 2011 - 05:08 PM
checked the thermo fuse today and that was the problem, was able to get one in town and is now working...thank you!!
I however couldn't figure out what caused it to go, the lint trap was clean as well as the fan and tube going outside. I did find a ball bearing on the ground that is from the back of the machine that goes against the drum bearing but the metal strap piece thats suppose to keep it in place from falling out the back is broken so i can't get it to stay in. would this cause much of a problem with running the machine??
thanks
#8 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 04 April 2011 - 05:44 PM
Make sure the dryer doesn't heat in the "air only" cycle
The bearing is a grounding ball,
I personally would replace it
Bracket link
If you are sure that all the venting is clear and
you continue to blow fuses you may need this kit.
Heater air flow kit link
Has the dryer been in its current location for long?
#9 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 04 April 2011 - 06:29 PM
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
Frigidaire FDE647RFS1 dryer - won't start
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 03 April 2011 - 07:03 PM
Fuse Link
The fuse is attached to the right rear wall of...
Read Full Entry →
