Whirlpool Duet GHW9150PW0 - no spin or tumble
12 replies to this topic
#1 Toolnalong
Toolnalong
  • 6 posts
  • Flavorite Brew:Sam Adams light
Posted 03 April 2011 - 08:42 PM
I have a whirlpool duet model # GHW9150PW0, last year, I had to replace the MCU, seen it was burnt, everything worked great, till the past nov., I noticed the motor was starting to very noisey, I replaced the motor yesterday after it finally went about a week ago, and was setting an F06 code, after putting the motor in, it runs thru the cycle, but the tub does not aggitate or spin, I have checked all wiring connections at the MCU, motor, and CCU, checking the wiring in between, I am at a loss, I do not know what all of the pins voltage, ohms are suppose to be to truely check and diagnois this, can you please help me?
#2 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 03 April 2011 - 08:50 PM
are you still getting a code?
#3 Toolnalong
Toolnalong
  • 6 posts
Posted 03 April 2011 - 08:56 PM
no codes
#4 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 03 April 2011 - 09:00 PM
Do you have the tech sheet that came with the unit that should be attached inside of the cabinet? If so, have you ran diagnostics?
#5 Toolnalong
Toolnalong
  • 6 posts
Posted 03 April 2011 - 09:14 PM
where in the cabnet is the tech sheet?
    Shōgun
  • Master Samurai Tech
  • 30,209 posts
Posted 03 April 2011 - 09:56 PM
Remove the top panel (three screws in back) and the you'll see the tech sheet in a plastic pouch taped to the inside right panel.
#7 kdog
    RoughShod
  • 7,466 posts
Posted 04 April 2011 - 12:39 AM
You may also find it behind the lower front access panel (also 3 screws), in the same plastic pouch stuck to the inner side panel
#8 Toolnalong
Toolnalong
  • 6 posts
Posted 04 April 2011 - 02:26 PM
no dianostics on this machine, ran it with a normal load, no codes setting, does not aggitate or spin
    Shōgun
  • 30,209 posts
Posted 04 April 2011 - 02:33 PM
no dianostics on this machine...
Oh, but I beg to differ!
Have you located the tech sheet? It will explain how to run the diagnostics.
#10 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 04 April 2011 - 02:39 PM
PDF page 7 of the tech sheets
#11 Toolnalong
Toolnalong
  • 6 posts
Posted 04 April 2011 - 02:59 PM
there is no tech sheet anywhere in this machine, that I can see, I have the top off, the lower front cover, and the back off, I see no tech sheet, must have not been put in from the manufacturer, we bought this new
#12 RegUS_PatOff
  • 33,588 posts
Posted 04 April 2011 - 03:45 PM
Page from Tech Sheet - 8182277.pdf
For manuals and lots of other goodies,
become an Apprentice==> http://appliantology.org/apprentice/
#13 Toolnalong
Toolnalong
  • 6 posts
Posted 05 April 2011 - 07:21 PM
ran diagnostics, no codes, no aggitate or spin, whats next?
