Bosch D/W Model# shu43c06uc/17
1 reply to this topic
#1 Skiter29
Skiter29
    Kohai
  • 370 posts
Posted 08 April 2011 - 11:33 AM
Did a recall on the bosch d/w im not a authorized service customer called me to do was fairly easy except i didnt really understand the code instructions called bosch for help no help there i think i got it right but not sure i have a Model #SHU43C06UC/17 Serial fd640500725 and the code i programed in there was #21 can anybody out there tell me if this is the correct 1 the coding on the sheet said coding #1 for this model
    Shōgun
  • Master Samurai Tech
  • 30,625 posts
Posted 09 April 2011 - 07:59 AM
Replacing and re-programming the control in these Bosch dishwasher is a pretty straightforward job. But the instructions for the reprogramming are a little different from what you might actually see.
Here's a video showing how to replace the control.
And here are the written instructions from Bosch (click to enlarge):
In the video, the re-programming portion is the last 30 seconds or so of the video. Notice that what they show in the video doesn't quite match up with what's shown in the video, in particular, the programming code shown in the display. In the video, you see him cycle through a series of programming codes from 20 through 29 (this is how you'll usually see it in the field for models with the LED display) until he gets the code he wants, in his case, "21."
In the written instructions, OTOH, they talk about programming codes of C0 through C4. The discrepancy is that in the written instructions, they're using "C" to mean "code." On the display, just ignore the first number ("2") and go by the the second number that changes as you cycle through it.
So, if your model number is SHU43C06UC, the target code is "1" and you cycle through until you see "21" in the display.
How to replace and reprogram the main control board on Bosch dishwashers
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 09 April 2011 - 08:00 AM
Here's a...
Read Full Entry →
