Frigidaire FTF2140FS1 washer won't spin
#1
Posted 10 April 2011 - 02:30 PM
#2
Posted 10 April 2011 - 02:45 PM
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause/Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs.
The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes
#3
Posted 10 April 2011 - 03:46 PM
#4
Posted 10 April 2011 - 04:24 PM
is" no spin selected"
try to change it and try agian
#5
Posted 10 April 2011 - 04:49 PM
#6
Posted 10 April 2011 - 05:57 PM
Cycle Lights, how many times ?the error cod it beeped 3 times with all the cycle lights flashing and the start light.
start Light, how many times ?
did you click on the page the Samurai linked to ?
#7
Posted 10 April 2011 - 06:12 PM
#8
Posted 10 April 2011 - 06:44 PM
#9
Posted 10 April 2011 - 06:50 PM
#10
Posted 10 April 2011 - 07:01 PM
The Tech Sheets says Control Board problem, but others have reported that any 4x code was a bad Door Lock Assembly
#11
Posted 10 April 2011 - 11:08 PM
#12
Posted 15 April 2011 - 05:06 PM
#13
Posted 16 April 2011 - 06:41 AM
We've been focusing on the no-spin complaint. Does the drum tumble? Does the drum move at all? Some other possibilities at this pernt:
- something mis-wired or a harness not seated all the way, re-check all your wiring at both the door latch assy and the motor control board
- broken belt
- bad motor
#14
Posted 16 April 2011 - 04:11 PM
#15
Posted 16 April 2011 - 06:18 PM
Motor Controller Link:
#16
Posted 16 April 2011 - 06:37 PM
#17
Posted 16 April 2011 - 06:42 PM
#18
Posted 16 April 2011 - 07:48 PM
#19
Posted 16 April 2011 - 08:00 PM
and if not stolen during any service work
#20
Posted 16 April 2011 - 08:06 PM
