whirlpool duet ge9200lw
3 replies to this topic
#1 zenclan
zenclan
  • 2 posts
  • Flavorite Brew:flat tire (pun intended)
Posted 12 April 2011 - 08:55 PM
Yesterday my duet 9200 quit heating so I removed the heater and housing with the termal cut off and high level thermo. I took the unit to first source here in san antonio and had him test all 3. he said the heater was bad ans showed me a break in the element coil. So thrilled to pay the 94 bucks, I ran home and reinstalled. and I still have no heat...any ideas please..thanks
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 12 April 2011 - 10:22 PM
...the element coil ... So thrilled to pay the 94 bucks
Heater Assembly $ 48
http://www.repaircli...?R=154&N=525502
The Dryer Drum runs OK ?
Re-set the House Circuit Breakers for the Dryer.
#3 zenclan
zenclan
  • 2 posts
Posted 13 April 2011 - 01:50 AM
yes drum runs fine and reset breakers
#4 RegUS_PatOff
  • 33,588 posts
Posted 13 April 2011 - 06:25 AM
Disconnect the large Red Wire from the Terminal on the Heater Relay on the Electronic Controller Board.
Run the Dryer in a normal Timed-Dry Heat Cycle.
Check for 120v AC from the disconnected Red wire to chassis (ground)
and then check for 120v AC from the (empty) Heater Relay Terminal to chassis (ground)
