GisMagik
Maytag Performa Dryer
29 posts in this topic
I have a Maytag Performa dryer that stopped tumbling this evening  :headbang:.  I am assuming that this is a broken belt of some sort, because it was running fine, there was a noise best described as a belt snapping and then the dryers sound changed from its normal.  So my questions are...
1) Is this just a belt from the sound of it?  If not, any guesses?
2) How difficult would it be for an unotherwise mechanically inept husband (or me, probably!) to fix?
Yes sounds like a broken belt, post the model number so we can see what is inside of your dryer.  Click on this link to read how the belt goes on Maytag dryers.
This link will show you how to take it apart.....;)
PYE2300AYW = Model Number
Thanks for your help, with four kids, the quicker and cheaper this problem is the better!!!
Welcome, the links should get you going in the right direction.  Check the blower wheel while in there, they do round out.  ;)
Thank you for your help.  We got the dryer open and it is so very definately the belt.  It was shredded.  It appears that the belt started slipping some time ago and got caught on a bolt on the drum.  We are headed to a supply store tomorrow to get the parts.  I'm glad it happened, there was quite a bit of lint trapped where we never knew to look!  I am a bit concerned because the idler wheel and motor are behind the drum & also the blower wheel, so if anyone has any suggestions on how to take care of restringing the belt considering the tight spot, I'd appreciate it!
I did want to mention that the Maytag Performa is more like the Norge dryers , pictured on this  sitefor disassembly purposes, in case anyone else is lurking.
Thank you Thank you for empowering us to tackle this on our own.  Here's to getting the job done!
You are very welcome....;)
Great observasion Grasshopper, That Maytag Performa is a Norge dryer. Maytag now owns Norge.
And getting that belt on is kind of a blind one handed operations. Stick right hand in, put belt around motor pulley then grab idler pulley and pull back while using thumb to hook belt around pulley.
Alrighty gurus,
I got the belt, I seem to have it on the motor and pully the right way, however when the drum spins the belt seems to move forward about 1/2 inch so that it is riding along a bolt in the drum, what is causing it!!!  HELP!
:yikes:
Hard to tell without seeing what you have done.
Are you sure you got the belt on the motor pulley. If you somehow got the belt around the motor shaft instead of the actual pulley it very well could be the problem.
If where I am pointing to is the motor pulley, then I got it right.  It is resting where the grooves would make contact with the "pulley"
Actually the belt had left a mark on the drum before it snapped and that is where it seems to want to rest.  It shimmy's out of the "V" on the drum forward about a half an inch!  If I can get a picture of it I will!
Here is a couple of pictures of my dryer.
This is a view of the top of the dryer.  Note the belts position on the drum between the "V" and the bolt.  Under the belt is a black mark the old belt left.  For some reason this is where the belt wants to sit....any suggestions?
This is the best picture I can get of the pulley and motor with belt strung.  The camera is in the back of the dryer facing toward to front.  Very difficult to get, my arm is a bit scratched up after of this?
Thanks for looking and making suggestions!
Kim
Good pictures. The belt is not supposed to ride in that drum groove-- they put that there to confuse grasshoppers and give appliance techs job security. The fact that the new belt is riding over the black smudges left by the old belt means that it is positioned where it's supposed to be.
What's the problem here?
Thanks for the reply!  Now I can finish the laundry from my 2 week vacation, that has now been sitting for an extra week!
ROCK ON SAMURAI APPLIANCE GURUS!!!
KimB
I'm back!  :huh:
My dryer, previously seen here:
http://applianceguru.com/view_topic.php?id=2229&forum_id=2&highlight=performa
is a Maytag Performa (PYE2300AYW = Model Number).  It won't start.  I initially hoped it was the outlet, but the outlet has power.  What else should I check?  and/or will I be able to handle this crisis or will I need to call in the troops?!
The belt was working great!!  :)
If you lift the top of the unit up there is a thermal fuse mounted on the heater assembly housing. Do you have a volt/ohm meter?? The fuse is a normally closed circuit when functioning correctly.
Help using a volt/ohm meter here.
The thermal fuse has continuity when the back switch is pressed manually with the dryer unplugged.  What's it mean?
For some reason, the electrician doesn't want to try this manuver with the power connected!!  :)
I bow to your samurai power and wisdom....
The thermal fuse when good should have continuity always. You lost me with the whole back switch thing. What switch? What were the colors on the component you checked so we can be sure it was the thermal fuse and not the hi limit.
ALrighy, I think you may be right, we were probably lloking at the hiLimit.  So here is what I'm looking at, if this isn't it, could you explain were I might find the thermal fuse?
signed
just a poor housewife!
It will look similar to what you have photoed but smaller. It will probably have at least one white wire on it and it will be to the right and down about inches down mounted to a bracket. It should read closed at all times. Now you state your electrician stated the outlet was good. Has anyone removed the metal plate off the back of the unit and inspected the lines coming into the unit? If they haven't. check there for burnt wires as well.
No burnt wires, I haven't had the time to tear the inards yet.  I'm thinking I'll need to remove the drum to look for the fuse.  I am not looking forward to this.
 I am beginning to think a new dryer or paying a samurai to fix this is gonna be a better idea!!
I am not a happy Maytag customer!!!:fingerwag:
The thermofuse is right under the heating element, will be black plastic.  If it is dead it kills the whole dryer.   Just remove the element to get to the fuse, you can see it with the element in place, just look down to the left from the right side of the element.
Do not give up!! You are right there. The thermal fuse is just out of the picture you sent in. To access the heater, remove the bracket that the hi limit mounts to and let it hang off to one side. Your heater can then be removed by taking out the one screw on the right hand side that mounts to the beater bracket. This makes accessing the Thermal fuse easier. Another comment if I may. Thermal fuses blow for a number of reasons, your belt breaking as stated in earlier posts can do it because the air flow stops and the heater stays on which will blow it. Another thing is improper venting. Looking at all the lint around the heater and back edge of the dryer, you might want to have it cleaned and make sure it is as instructed per your install book.
Guest
This topic is now closed to further replies.
