AZ Scott
LG WM2487H** Drain Pump: Good or bad?
6 posts in this topic
Hey All,
We're having a drain issue with our 4-year-old LG WM2487 front loader. If fills, washes, and spins, but simply won't drain any water. The problem came on suddenly. We did one load and everything was normal, but on the very next load we noticed a massive build-up of suds during the rinse cycle and we finally realized it didn't drain the wash water out.
Using the Samurai's excellent instructions listed elsewhere on the site, I was able to access the insides of the machine to check everything out...
So far I've ruled out:
- Clogged drain pipe... When I uncork the small drain hose in the front of the machine it flows, and if I remove the trap, plenty of water comes pouring out, so there doesn't seem to be a sock or anything blocking that area.
- Clogged exit hose... The entire drain hose is clear, and flows into a modern receptacle in the wall.
- Debris caught in the trap... No debris in the trap and no obstruction in the impeller area.
- Loose wire connectors... The connectors on the drain pump motor are nice and snug, and everything looks clean and dry.
- Bad water-level sensor... When the machine was full of water, the door stayed locked, but after draining some water manually it unlocked. I assume that means the sensor is operating properly.
Which brings me to the pump motor:
I pulled the entire drain/pump assembly out of the machine, and removed the drain pump motor. The impeller on the drain motor moves freely, and you can feel the magnetic pull of the rotor stopping the impeller each revolution. I hooked the motor up to A/C power on my bench, and the motor seems to spin freely and quietly.
One oddity I noticed (at least to my amateur eyes) is that when I pulled the magnetic rotor out of the motor housing, there was some nasty, grey, liquidy goop in there. Maybe a tablespoon's worth. It's gritty and watery, and smells like fish oil. I assume there should be some kind of grease or other lubricant in that area, but I don't know enough about electric motors to know what it should look like. As it sits in the open air, it's drying out, so there certainly seems to have been water in there that's evaporating.
Does this sound normal?
If so, and the motor is fine, then I'm kind of at a loss as to what's wrong. Could it be just a control box issue, and the motor isn't getting the proper signal? With a very basic knowledge of electronics, is there a way for me to test it?
Thanks in advance for your help!
<<<fills, washes, and spins, but simply won't drain any water.>>>
Was an "OE" error displayed?
<<<on the very next load we noticed a massive build-up of suds during the rinse cycle>>>
An "LE" error can be triggered by heavy suds.
Use only "HE" low-suds detergent.
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
<<<The entire drain hose is clear>>>
I remove the DRAIN HOSE at the Pump Housing & wrap a rag around it. Poke a hole in the rag. Blow thru the hose.
If there's a restriction/blockage---it'll be at the "U" shaped connector located at the left corner of the washer (if standing in front of the washer). This "U" connector---which is part of the DRAIN HOSE assy---is visible from the top of the washer (with the cover removed)and may have a blockage.
<<<when I pulled the magnetic rotor out of the motor housing, there was some nasty, grey, liquidy goop in there. Maybe a tablespoon's worth. It's gritty and watery, and smells like fish oil>>>
Not good. The seal in the DRAIN MOTOR has failed.
Some DRAIN MOTORS are known to "run" but not sufficiently fast-enough to pump out water.
Replace the DRAIN MOTOR.
NOTE: If your washer has *dual* motors on the Pump Housing---the DRAIN MOTOR is on the left side if facing the front of the washer.
Well, that answers that! If there shouldn't be anything inside that motor but air, then definitely this is our problem. I guess I'll be ordering a motor from you guys!
We didn't see any error code displayed that we remember, just the word "RINSE" flashing. Maybe if the motor was turning just a little bit, the machine didn't recognize an error?
Anyway, thanks for the input! :thanks:
Link to Pump:
UPDATE/CONCLUSION:
Well, alright!
I received my new drain pump motor just a few days after I ordered it, got it installed, and BINGO! The machine runs like a champ!
I want to thank you guys for your help. The diagnosis was spot on, the instructions I found on this site were VERY helpful, and you saved me who knows how much by not having to call a pro to come fix the thing.
Even learned a few things about our washer that you'd never see in the owner's manual, too!
Cheers!
:cheers:
- Scott
... Even learned a few things about our washer that you'd never see in the owner's manual, too!
For service manuals and lots of other goodies,
become an Apprentice==> http://appliantology.org/apprentice/
