Frigidaire Gallery GLTF2940F washer - incomplete draining and E21 error code
4 replies to this topic
#1 unXpected-repairs
unXpected-repairs
  • 2 posts
Posted 18 April 2011 - 01:18 PM
Hello fellow Samurai,
I have a Frigidaire Gallery GLTF2940F, that sometimes does not complete the wash cycle. There are 2 different things it does. 1 it claims to finish the wash but all the clothes are super wet. 2 it claims the wash is paused, and I can hit start and it will continue and finish (maybe require 2 to 3 restarts, before it finishes the wash).
My Error Code is: E21, "Water not pumping out Fast enough".
I have read this forum and the fixitnow forum for advise on my issue, here is what I have tired:
I have removed the drain hose and taken it outside and hosed it out on my lawn, so its definitely clear of obstructions. I took the same lawn hose and put into my drain pipe to make sure the drain is not clogged.
I removed the pump and opened it up as much as i could and cleaned it out, and the rubber thing in front of the pump, but the issues still occur.
Suggestions?
Thank you,
unXpected-repairs
#2 kdog
    RoughShod
  • 7,466 posts
Posted 18 April 2011 - 03:54 PM
After you have emptied all of the water from the pump trap - put unit on drain/spin cycle without adding any water and observe operation - does it spin up to high speed during this cycle ?
While you are in there, remove the stupid little catcher cup that's in the tub-to-pump hose and ditch it, only causes headaches (you might find it full of goodies causing your issue) Looks like this:
http://www.repaircli...il/Tube/1258686
#3 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 820 posts
Posted 18 April 2011 - 10:42 PM
It's nice to know that you can get rid of that "stupid little catcher cup". I've done alot of swearing getting those back in.
#4 kdog
    RoughShod
  • 7,466 posts
Posted 18 April 2011 - 10:48 PM
We'll call it a "swear jar" ! :groucho:
#5 unXpected-repairs
unXpected-repairs
  • 2 posts
Posted 19 April 2011 - 12:00 PM
Swearing cup indeed, but maybe because it is nasty. That maybe the problem indeed. I have removed it and ran and empty "drain spin", it went super fast. This is actually the first time I have actually watched this thing spin dry before, wow that drum can really go.
I havent run a load in the machine yet, because it got too late , but tonight I will run a load.
Thank you everyone!
-unXpected repairs
