"Vote Up" Not Working
Strathy
It would be nice for tech's to be able to vote up replies that we concur with ... when I do, I get an error message. A reply that has 8 or 10 votes up would really give it credibility.
post-55589-0-04971000-1303172825_thumb.j
actually, I've never noticed that was there ... :blink:
I'll look into this and see if I can figger out how to tweek it. Domo for the suggestion!
Strathy, were you able to vote up/down at all? The screen clip you included says that you reached your max voted for the day-- implies that you were able to vote prior. Oui?
I don't believe those have ever worked as I always got the same message - probably connected somehow to the "reputation" of the user
Still trying to figger out how to turn that on. I'll seek guidance from a higher source.
Sorry - I missed your question. No, it does not work at all. That message comes up the first time and every time you click the vote up button.
works for me, although once I give it a plus, I can't change it back
hhmmm... I can plus my own message ...
  • Like 3
I finally figured out how this system works. I think it's working now. Try it out and lemme know.
  • Like 3
although can't change your mind after voting..
and I can 'vote up" my own posts ...
Okay, think I got those bugz squashed, too. Lemme know!
  • Like 3
  • 3 months later...
Actually, it still is. They added several other "karma" systems in addition to the one retained from the previous version.
I kinda like the "Like" system, even if it seems Facebooky. Whatchyall think?
