Whirlpool EL7ATRRMS03 L1
#1
Posted 26 April 2011 - 10:51 PM
To the point. The fan is running, the coils are clean. The defrost timer is nearly brand new, and I ran it for two hours with the timer unplugged and timer-plug jumped to make the compressor run for sure. The compressor is making a weird noise since last night. I can't measure amps on the start/run because of the weird way they connect to the relay. Not sure if there is an easy way to test the relay. Hoping it's a relay or the capacitor. start/run windings are 9.7 and 7.5 ohms. Is this worth ordering a new relay and/or capacitor or should I just call the big-dollar man to replace the compressor?
Other stuff I left out- the weird noise sounds like the noise it makes for a bit while it starts, but it's making it all the time, but it isn't doing a run-click. I did short cycle it once today by accident and it did a proper run-click, but it cleared itself and started up again and went back to making the weird noise.
Thanks to all gurus.
Jeremy
#2
Posted 27 April 2011 - 04:10 AM
#3
Posted 28 April 2011 - 01:34 AM
http://www.youtube.c...h?v=iS4uY4kIs9o
The noise isn't real clear, but it usually isn't even noticeable in the kitchen, and when I first heard it I was in the next room.
So, it occurs to me today that I actually might have a known-good start relay and capacitor, in the freezer duh...
I opened her up and the relay is the same. The capacitor is 15uF instead of 10uF though-- the compressors are different. (I'd always assumed they just put a different thermostat in it)
I'm testing the fridge with the freezer start relay in there now, will update...
Oh yeah... The long and beautiful post didn't post. In it, I had mentioned that this is a full-fridge, and it sits next to its full freezer. The house was built around them. They look like a baby sub zero, but they are just two matching units with pretty stainless steel fronts.
That's the long and the short of it. (marriage explanation...) I bet you were wondering how I got a start relay from the freezer to put on the fridge eh?
Jeremy
Edited by jermitts, 28 April 2011 - 01:35 AM.
#4
Posted 28 April 2011 - 03:06 AM
I'm not really an electronics guy, I understand the basics of voltage and power and resistance and how capacitors do what they do (and I'm a wiz at the last 5 versions of the NEC!) but I don't know the ramifications of swapping a 10uF cap for a 15 on a lil' freon compressor. Magic smoke? I know that sometimes when an AC motor is having trouble starting and replacing the capacitor didn't fix it (old age or windings wearing or bushings failing or whatever really is going on) we've increased the capacitor size a bit to give it a little more help and no damage was done, get a few more months or years out of the thing, but considering the size of those motors and the size of this one, I'm not sure the logic translates.
One more thing, the capacitor at Repair Clinic for this model shows 12uF in the picture. Is that okay? I swear this one came with one that is marked 10uF. $50! Wow!
Thanks again,
Jeremy
*-PS it looks like there's one of these sidekick fridges for sale about 10 hours from me. Maybe a road trip this weekend?
Edited by jermitts, 28 April 2011 - 03:07 AM.
#5
Posted 28 April 2011 - 10:05 AM
1) if the Compressor is running for an hour and "no frost", then it seems like a system problem $ $... because after an hour I've still got no cold and no frost at all on the coils.
... sidekick fridges for sale about 10 hours from me. Maybe a road trip this weekend?
2) maybe
#6
Posted 28 April 2011 - 02:21 PM
#7
Posted 28 April 2011 - 04:15 PM
trivia fact.. when you put you hand over the Vaccuum cleaner Hose, and the Motor revs higher..... like putting your hand over the end of a vacuum hose changes the sound of the motor.
it actually has less of a load and the amperage decreases ..
#8
Posted 28 April 2011 - 08:09 PM
#9
Posted 28 April 2011 - 08:43 PM
That just sounds too good to pass up (and the nearest matching one is $600 and a 10-hour drive and $350 in gas or $300 to ship!) so we're gonna take it in on Monday, if tha loard willin and the creik dont rise.
Thanks for the guidance, as always.
Jeremy
#10
Posted 28 April 2011 - 08:55 PM
Actually, that's quite likely what has happened - the leak is likely at a welded joint or corroded area of the tubing, or in the aluminum evaporator coil (such as where the defrost switch is clipped), your compressor may still be ok - although it's replacement is always recommended since the compressor has run full of air/humidity."what if it turns out to be leaking out somewhere else?" (I know, rare, but it happens, yeah?)
Look at the tubing carefully and you might see some tell-tale signs of oil around the leak area
#11
Posted 28 April 2011 - 09:52 PM
I keep reminding myself that I only gave $1400 for both halves of this. MSRP was about $3200, but I doubt anyone ever paid that for them.
Jeremy
(here's generic pics)
Edited by jermitts, 28 April 2011 - 10:01 PM.
#12
Posted 28 April 2011 - 11:26 PM
