wtw6200vwo whirlpool - installing the rotor position sensor
4 replies to this topic
#1 serv.man
serv.man
    Ikkō-ikki
  • Chief Appliantologist
  • 33 posts
  • Flavorite Brew:martini
Posted 28 April 2011 - 12:27 PM
I replaced the rotor position sensor now I cant get the drive motor rotor assy. back on it seem to be to tight.I am not to sure how tight it should be. HERB
  • 24,714 posts
Posted 28 April 2011 - 01:00 PM
Trnonicsmasta put together a killamanilla guide on these buggers, come check it out.. http://fixitnow.com/...lacement-guide/
Also, if you need the service manual for this unit, lemme know.
#3 serv.man
serv.man
    Ikkō-ikki
  • 33 posts
Posted 29 April 2011 - 10:53 AM
I replaced rotor position sensor. Now I cant get the motor rotor assy back on.It seem just tight to slide over motor stator assy.How tight should that fit.their is no way I can just slide in back on.Iam at lost as what to do.Can anyone give me some ideas.Is their any I could have put the stator assy. on wrong it just on with four bolts.HELP HELP HELP. HERB
  • 24,714 posts
Posted 29 April 2011 - 04:48 PM
Topics merged.
#5 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 699 posts
Posted 29 April 2011 - 09:27 PM
The magnets will pull the rotor assy onto the stator. It feels funny. You have to line the splines up on both parts then get the center bolt started and by tightening the bolt it will pull both parts together. You might have to give it a few tries to get the splines lined up, those magnets are strong.
Edited by SANTA, 29 April 2011 - 09:28 PM.
Tips for installing the rotor position sensor in a Whirlpool Cabrio - Maytag Bravo - Kenmore Oasis washer
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 29 April 2011 - 09:53 PM
The magnets will pull the rotor assy onto the stator. It feels funny. You have to line the splines up on both parts then get the center bolt started and by tightening the bolt it will pull both parts together. You might have to give it...
Read Full Entry →
