Sign in to follow this
Followers 0
aprilh
GE Model DBXR453GT
3 posts in this topic
Hi. I'm new. My dryer started making a really bad grinding noise, so I decided to take it apart. My husband is useless with this stuff, so it's just me. I eventually figured out the blower wheel's retaining clip needed to be tightened. Took care of it, but took apart the drum and all first. Can't figure out how to get the belt back on. I wrapped it around the drum and have no clue how to get it around the pulleys. The manual is useless and I can't really find any diagrams online. Just wrapping it around isn't working because the belt is too long for just that. Any chance there's a diagram somewhere to help?
Going from the gray matter, put both arms into the unit ,one to the left of the drum and one to the right near the bottom, left arm over the blower........... On the left side, the belt will go down from the drum, under the motor pulley, up on the right ,,Use your right hand and pull the Idler pulley to the right and lay the belt on the top of the Idler pulley...... let the Idler pulley return to the left slowly..........Viewed from the front, belt down on the left, under the motor pulley up and over the idler pulley.... continuing up and to the right , over the drum......... :blink:
View the part link for a little die a grama
Followers 0
