GE Profile Refrigerator - Water Supply Line
1 reply to this topic
#1 olimazi
olimazi
  • 1 posts
  • Flavorite Brew:Miller High Life
Posted 05 May 2011 - 11:44 AM
I have a GE Profile Refrigerator (bottom freezer type w/ icemaker) - will post model # when I get home;
We had a leak from the water supply line - plastic GE SmartConnect tubing.
The line coming from inside the refrigerator halfway down the fridge to connect to the water supply line from the basement had a crack in the tubing.
I got an icemaker replacement tubing kit from home depot, however I cannot access the water line tube that goes into the back of the refrigerator to the water filter inside.
It goes way in and I can't even see where it connects, let alone find the connector to disconnect.
Do I have to take off the back metal plate of the fridge to access this connector?
Can I cut the tubing and reconnect it to the existing pipe connector somehow, so I don't have to access the back of the fridge?
Any help would be appreciated, thanks!
GE Fridge <--- link to picture of what I'm trying to describe.
  • 24,296 posts
Posted 05 May 2011 - 01:55 PM
Just cut the tubing at a place where the tubing is in good condition and use a John Guest tube splice connector.
More on John Guest fittings here... http://fixitnow.com/...tings-revealed/
