Maytag wide-by-side MZD2766GEB...three guesses what's wrong
#1
Posted 06 May 2011 - 02:06 PM
now, on to the Maytag wide-by-side. Three guesses what the problem is, but you'll only need one. Frost in the back of the freezer, fridge not cooling. I'm out of work now, so looking to save some $$, I googled the problem and wound up here, though every hit I got seemed to suggest the ADC was bad. Saw the 365-day return policy here and since the best anyone local could do was a week later, I ordered. Problem is, I didn't completely read the thread (Five page thread on this from several years ago), I'm not an electronics guy, pictures and links are missing, and it's a bit hard to follow some of the conversations.
I managed to locate and replace the board, but I THINK what I have to do now is short L1 to test. Like I said, I'm not an electronics guy, so while I can take a guess, I'm not 100% sure what that means and how to go about it. I have a multimeter, but have never used it (and really don't know how...I got it free w/ coupon and purchase a Harbor Freight...free is good, I'll figure out what it is later, right?!?!). Would someone be willing to give me a step-by-step and/or electronics 101 to help fix this? I'm a handy guy, fixing and building stuff all the time, so I don't need idiot proof directions, but the kiddie version would be helpful.
Thanks!
#2
Posted 06 May 2011 - 02:21 PM
On the "older" ADC, the first and second pins MAY be labeled L1 and TEST.
If not, you have the "newer" style ADC (see below)
Turn the Cold Controls to MAX cooling.
The Compressor should run.
Momentarily short L1 and TEST pins together with the tip of an insulated screwdriver.
The Compressor should stop running, and should energize the Defrost Heater.
If the ADC "buzzes" it's bad.
The newer style ADC may not have the L1 and TEST pins ..
(there's another way to activate Defrost)
#3
Posted 06 May 2011 - 02:51 PM
#4
Posted 06 May 2011 - 03:12 PM
#5
Posted 06 May 2011 - 03:23 PM
... and a few towels..... as I go try to find the wife's hair dryer:
... The old one has L1 and test marked..not sure about the new one. Should I short that on the new one?
yes, if it has those pins labled L1 and TEST,
otherwise on the "newer" ADCs, it's easier..
I think its "turn cold control ON /OFF 3 times within 6 seconds, then leave on MAX cold"
