FAV6800AWW Will not drain
#1
Posted 06 May 2011 - 04:40 PM
#2
Posted 06 May 2011 - 05:02 PM
If not, then it's either a bad Main Controller, or Wiring / Connectors
#3
Posted 07 May 2011 - 12:53 PM
If you did you could go into to Service Mode and turn on the drain pump on from the console and check for proper operation.
Here is the process to turn on the drain pump in service mode;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub. See if you can turn on the drain pump in Service Mode here is the process.
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Next pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
If the drain pump turns on then I would hose or bucket fill the washer to at least 7” of water in the wash basket. Then turn on the drain pump in service mode. It should take 20 to 30 seconds to dump the water. If it does not we need to do further Drain Pump and or Drain Line troubleshooting.
Good luck.........Dick
Edited by dh1200s, 07 May 2011 - 12:55 PM.
#4
Posted 07 May 2011 - 01:31 PM
become an Apprentice==> http://appliantology.org/apprentice/
#5
Posted 08 May 2011 - 11:33 PM
#6
Posted 09 May 2011 - 12:01 AM
#7
Posted 09 May 2011 - 01:38 AM
PBK you enter into Spin Cycle of the wash cycle and the wash basket/tub bangs around failing with unbalance error codes dc or UC is that correct? If you terminate that cycle and start a Spin Only Cycle I'm sure you fail out with dc/UC error codes.
If so the One-Way Clutch bearings in the Clutch Pulley are slipping they need to lock up ROCK SOLID in Spin Cycle.... CCW rotation of the Wash Basket. If they slip as you enter into Spin Cycle you will get agitator shaft/tumbler movement which drags the wash load off balance resulting in BIG Time Wash Tub swings. The TDS will signal the Control Board of the Out Of Balance condition, the Control Board will halt the Spin Cycle, rotate the tumblers for a few rotations to redistribute the wash basket load then start the spin cycle again. If the Out Of Balance condition continues and after for a few more wash load redistribute attempts the Control Board will say enough of this and signal a dc or UC error code to the LED display.
You could drop out the Clutch Pulley and inspect..... maybe clean up the One-Way bearings in the Clutch Pulley and the Upper One-Way bearing ring if used if they are not severely rusted up as certified tech group 51 mentioned.
I have an old write up somewhere on this forum to help you troubleshoot the issue and remove the Clutch Pulley for inspection/maintenance. I have no clue where it is. I have sticky on another forum with all the details of this issue. You could throw another Clutch Pulley in the machine and maybe work for a few more months. But I feel you are ready for an Outer Tub rebuild or at a minimum Tub Seal replacement. This is a very cost effective DIY repair for the handy owner.
Good luck............Dick
Edited by dh1200s, 09 May 2011 - 01:39 AM.
#8
Posted 09 May 2011 - 11:18 AM
You described the problem exactly. When I get home I will check the clutch. I have downloaded the Service Manual. I still have the old pump. I can use it as a future spare. I will report later.
#9
Posted 09 May 2011 - 02:23 PM
I’m an owner like you and hate to see folks trash a $1K machine if they are a bit handy and like to pay themselves $ rather then repeated service calls.
With a little hands on and some basic guidance I feel you will find the machine is very easy to work on except for the location of that darn drain pump and pressure switch location.....some fun right? Based on the age of the machine I feel you are ready for an Outer Tub rebuild that will give you another 5 yrs + out of it. Other issues will come up as with any washer and all are fixable at reasonable cost if you can tolerate some down time to pick up parts and DIY.
There is misinformation out there that you need to replace the “Outer Tub to Get New Bearings” that is just not so for DIY owners. I can point you to my post where several other owners have rebuilt the Outer Tub on both FAV6800A and FAV9800A machines of both original Outer Tub design and the redesigned Outer Tub for these TL’s at reasonable cost. I won’t quote $ it’s better to hear it from the DIY owner that has completed the process.
Back to the unbalance errors, Google this Neptune TL Washer FAV6800AWW I discuss Clutch Pulley issues and other common issues with the machine.
Read through the sticky in Part 1 I describe the issue dc/UC unbalance errors in Spin Cycle……. what is the cause. Part 2 the fix. Again keep in mind I feel you are ready for a Tub Seal replacement based on the age of the machine. If you get away with Clutch Pulley One-Way bearing maintenance or have to replace the Clutch Pulley this will be a temp fix and I can’t give you a feel for how long. Ya need to fix the Root Cause of the issue.
If you need to replace the Clutch Pulley, you can get it right here.
