GE Washer WPRB9220C0WW Giving E43 Failure Code
2 replies to this topic
#1 Ritz
Ritz
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 556 posts
Posted 12 May 2011 - 09:59 AM
GE Washer WPRB9220C0WW Giving E43 Failure Code. The failure code indicates excessive brake time.
Is there an affordable way to fix this problem? Thanks in advance for any advice!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 12 May 2011 - 12:37 PM
Speed sensor input is also used by the electronic control board to calculate brake stop time. If, within a
1-year period (400 washes), the control board detects 3 stop times in excess of 25 seconds, the control
will determine that a catastrophic brake failure has occurred. The unit will immediately be disabled and
will display error code E43 on the Digital Seven Segment Display (DSSD). The unit will power up, but
no cycle selection will be available. The unit will remain disabled until the error code is reset using
service mode.
To test the speed sensor:
1. Place the unit in service mode and index to the Spin Fast Test.
2. Press the START pad and monitor the DSSD.
An rpm displayed on the DSSD indicates an operating speed sensor. No rpm displayed on the DSSD indicates a faulty speed sensor or faulty wiring.
When replacing the transmission, the speed sensor and magnets must be transferred to the replacement transmission.
GE 31-9095
link PM'd
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 13 May 2011 - 08:24 AM
The failure code indicates excessive brake time. The problem will either be in the speed sensor or in the transmission / brake assembly. It's easy to test the sensor to determine whether or not it's good, here's the procedure:
[quote name='RegUS_PatOff' date='12 May 2011 - 01:37 PM' timestamp='1305221835'...
Read Full Entry →
