Frigidaire Front Load Washer FWT449GFS2
5 replies to this topic
#1 manchmal
manchmal
  • 3 posts
  • Flavorite Brew:rice beer
Posted 16 May 2011 - 02:21 PM
Sensei,
I thought i had narrowed down the choices and i bought a new door latch assembly, installed it and it worked for about a month. (My washer was not agitating or spinning but would fill and drain and the timer would advance....aka: soggy clothes syndrome). I am not sure how to figure out electrical stuff so this was an 'educated' shot from internet research. Now the washer is back to where it was, no agitating or spinning. Is it the control board? On this machine it is a $350-$400 part....(ugh....) Of course there is no return for the door latch assembly....bought locally.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 16 May 2011 - 03:32 PM
early Frigidaire Gallery
131788200 EARLY Gallery SPEED CONTROL.pdf
    Shōgun
  • Master Samurai Tech
  • 29,382 posts
Posted 16 May 2011 - 03:39 PM
Let that be a lesson to you: always buy your parts through this website and get the peace of mind of a one year warranty!
There's a troubleshooting tech sheet inside the washer, remove the bottom kickplate to get it. There's a procedure in there to get you on the right track with this. Start with that and post your findings. I also have a troubleshooting flowchart on this page. Pay special attention to the note about the molex connector on the motor!
The fact that it worked for a month after replacing the door latch assy makes me suspect a wiring issue. Remove the wires and reseat them in the door latch.
Next, check the dispenser door magnet and reed switch. If the washer thinks the dispenser door is open, it won't run at all.
#4 manchmal
manchmal
  • 3 posts
Posted 16 May 2011 - 03:40 PM
Yes,....this is the tech sheet....I'm not sure what i'm supposed to be looking at....
#5 manchmal
manchmal
  • 3 posts
Posted 16 May 2011 - 04:20 PM
Ah. Husband took out door latch assembly and reconnected it. It worked....and then didn't. I don't think it's the dispenser door magnet and reed switch. The washer does go...it fills and drains but does not agitate or spin.
    Shōgun
  • 29,382 posts
Posted 17 May 2011 - 01:05 AM
... I also have a troubleshooting flowchart on this page. Pay special attention to the note about the molex connector on the motor!
