josh.a.ferguson
WED6600VW0 - Whirlpool Cabrio keeps blowing thermal fuses
5 posts in this topic
Hello All,
I have a Whirlpool Cabrio Washer and Dryer, about 5 months ago the dryer blew a thermal fuse. I replaced the fuse (figured I was done), and then several weeks later it blew again. This time, I replaced the cap from the dryer vent, used my shop vac to see if there was anything blocking in the vent. (The vent is about 20 feet from the dryer to the outside, runs through the crawl space). I then replaced the fuse again, it lasted about two weeks and then blew. I replaced it again just to get the unit back up and running and then two days later it blew again. So I am now on fuse number 4, and am frustrated as hell. There has to be another cause than just lack of airflow. Any thoughts on this?
TIA,
--Josh
What material is your dryer vent made out of (rigid aluminum duct, PVC, slinky-collapsible, etc.)? Better yet, post a picture of your vent here.
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
20 FT Dryer Vent Brush
http://www.repairclinic.com/referral.asp?R=154&N=424663
if ur vent is clear the heater relay is hanging up in control board had a couple of these already
also, Heating Element may be partially shorted to chassis (ground)
