  • Announcements
bmmc
kitchenaid defrost cycle
3 posts in this topic
how do i force the adc board into the defrost cycle?
FYI - this info is on the tech sheet supplied with every fridge, which is wadded up and tucked into a crease on the back of the toe grill. Should always go by the tech sheet because procedures vary widely. Tech sheets trump service manuals, too.
STEPS TO ENTER ELECTRONIC DEFROST CONTROL TEST MODE (IF APPLICABLE)
OPTION #1 STEPS (BI·METAL CLOSED):
#1 - POWER OFF TO REFRIGERATOR FOR AT LEAST 30 SECONDS
#2 - THERMOSTAT OFF
#3 - POWER ON TO REFRIGERATOR
OPTION #2 STEPS (BI-METAL CLOSED)
#1 - THERMOSTAT OFF 15 SECONDS
#2 - THERMOSTAT ON 5 SECONDS
(REPEAT STEPS 1 AND 2 TWO MORE TIMES)
#3 - THERMOSTAT OFF
ENTER TEST MODE
IN 3-8 SECONDS, CONTROL WILL TURN ON DEFROST HEATER.
DEFROST HEATER WILL TURN ON FOR 18 MINUTES OR UNTIL BI·METAL OPENS.
TO TERMINATE TEST EARLY, REMOVE POWER FROM REFRIGERATOR.
NOTE: IF OPTION #2 DOES NOT WORK, TRY OPTION #1 BEFORE REPLACING CONTROL.
ALWAYS CHECK CONNECTIONS BEFORE REPLACING CONTROL.
HELPFUL HINT: UPON ENTERING TEST MODE, A RELAY TURNS OFF THE COMPRESSOR AND TURNS ON THE DEFROST HEATER.
LISTEN FOR THE RELAY TO CLICK.
IF RELAY CLICKS ONCE UPON ENTERING TEST MODE, CHECK FOR DEFROST HEAT.
IF RELAY CLICKS TWICE (ALLOW UP TO 30 SEC BETWEEN CLICKS), CHECK FOR BI·METAL OPEN.
* * IF BI·METAL IS BY·PASSED FOR TESTING (IF APPLICABLE), DO NOT OVERHEAT EVAPORATOR AREA.
