Whirlpool Oven Model # RBS305PDQ16
8 replies to this topic
#1 Gerry
Gerry
  • 4 posts
  • Flavorite Brew:Smithwick's Irish Ale
Posted 17 May 2011 - 08:20 PM
My Whirlpool Oven Model # RBS305PDQ16 recently started making a buzzing noise briefly each time the elements cycle off.
This has been happening for a few weeks without affecting the oven's operation until today.
It seems as though it may not have cycled the elements off correctly today and caused food to burn.
I tested the oven after the burning incident, however, and the elements did cycle on and off, but still with the buzzing sound.
I hope you can tell me what part/s may be about to fail.
Gerry
#2 certified tech group 51
  • 2,678 posts
Posted 17 May 2011 - 09:14 PM
Sounds like a relay is starting to fail on the control board...With the food burning, the relay stuck closed.....repairclinic, P/N 831919 (R/C item 1179543 ) for about $ 169. clams :thumbsup:
    Shōgun
  • Master Samurai Tech
  • 30,577 posts
Posted 18 May 2011 - 11:25 AM
Part link to the control board... http://www.repaircli...l-Board/1179543
Comes with a one year warranty and if it doesn't fix it, return it for a refund, even after it's already been installed!
#4 Gerry
Gerry
  • 4 posts
Posted 28 May 2011 - 04:33 PM
Thanks for the help!
I ordered the board and installed it, but I now have another problem.
After putting in the new control board, I now get an F2, E1 error.
I reinstalled the original control board and I still get the F2, E1 error, so I don't think the new board is the source of the error>
What do you think is wrong?
Gerry
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 28 May 2011 - 05:48 PM
F2 E1 Keypad keytail not connected
1.Disconnect power or unplug oven.
2.Check keypad connector for firm connection.
3.Press CANCEL. If error code returns after 60 sec., replace keypad.
4.Replace control.
#6 Gerry
Gerry
  • 4 posts
Posted 28 May 2011 - 08:31 PM
Thanks!
I did as you instructed and the error remains.
Also, when I pressed cancel there was no beep.
There were two or three other buttons that didn't make a beep when pressed (all of the others did beep when pressed).
The same buttons made no beep sound when I reinstalled the original control board.
So, it must be the keypad that's bad. I noticed a kink in the ribbon cable, I must have damaged it when I installed the control board.
Do you have a part number for the keypad? The oven finish is white, & the Model # is RBS305PDQ16.
Gerry
#7 RegUS_PatOff
  • 33,588 posts
Posted 28 May 2011 - 08:45 PM
Touchpad assembly # 1
http://www.repaircli...?R=154&N=831540
#8 Gerry
Gerry
  • 4 posts
Posted 07 June 2011 - 06:49 PM
One more question!
When I clicked on the picture in your post of the Touchpad, the page that came up gave item# 831540 and referred to the part as Touchpad and Control Panel.
The price shown was $301.65.
Does this rathrer high price and the description "and control panel" mean that this comes with a control board, P/N 9302994, (which I already bought)?
If so, I'll get an RMA to return the control board I already bought.
Gerry
#9 RegUS_PatOff
  • 33,588 posts
Posted 07 June 2011 - 07:20 PM
... Does this rathrer high price and the description "and control panel" mean that this comes with a control board,
no, :confused:
the ToiuchPad is #1 in the picture, the Control Panel (frame) is right behind it.
The Control board is # 3
