Asko T721 dryer is tripping internal breaker on dryer
2 replies to this topic
#1 swenson
swenson
    Sōhei
  • 178 posts
Posted 18 May 2011 - 07:53 AM
What can cause this what should I check thank you
    Shōgun
  • Master Samurai Tech
  • 31,383 posts
Posted 18 May 2011 - 08:57 AM
Bad air flow will do it. Check that blower wheel down in front. It's smaller than the one on most dryers and if gets even what seems like a little lint built up on it, it'll greatly reduce air flow through the dryer.
Now, lint build up on the blower is usually a sign of another problem: poor air flow through the vent. Usually these dryer are tucked into tight spaces and the vents are the collapsible slinky stuff that gets all kinked and crimped when the dryer is pushed back into place. That's a Bozo no-no!
Think in these things, my fine young Apprentice.
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 18 May 2011 - 09:31 AM
not sure on Askos, but partially grounded Heater Element ?
from request forum:
ASKO_T700-Series Service Manual.pdf
Service-Manual-Dryers-EN Asko 700 Series.pdf
2_T720.pdf (parts)
8061867 KTD22-01.pdf (wiring diagram)
links PM'd
