Whirlpool Duet dryer model# GEW9200LQ0 won't start
1 reply to this topic
#1 Sauce73
Sauce73
  • 1 posts
  • Flavorite Brew:Sam Adams and Jack Daniels
Posted 18 May 2011 - 09:12 AM
Whirlpool Duet dryer model# GEW9200LQ0 drum won't turn. Sensing light is lit and timer counts down, it seems like dryer thinks it's working but no drum turn and no heat. NO error codes are displayed. Continuity checked out ok on Thermal fuse, thermistor, heat element, door switch, belt switch and drive motor. I believe it is narrowed down to the control board or touch panel board? Any suggestions on which is more likely to be bad?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 18 May 2011 - 09:39 AM
while the Dryer thinks it's running,
check the voltage from each side of white Thermal Fuse to chassis (ground)
