  • Announcements
wongro
SubZero 532 refrigerator side frost, no/low door suction and leak
8 posts in this topic
My refrigerator has had frost for months located at refrigerator side at the back middle left. Recently, I attempted to remove the frost by turning both freezer and refrigerator temperature control to 0 and took the time to clean the box. When I was done, I turned the freezer size back to 4. It stays cold. I turned refrigerator side back to 5 eventually to 9 and wait for half day, the temperature is still 40F. Also, it seems refrigerator side door suction is gone. The same spot used to have frost now have condensation.
What's more? I saw water leak at top left foot at outside. Leak stop when I shut off the water feed to ice maker. There is no leak from the water source to the ice maker valve.
Any help to explain why?
Edited by wongro
You've had what we professional appliantologists call, "a leak." Sub-Zero had a rash of them on this model a few years back-- I'm surprised to hear of this one cuz I thought they woulda all been dealt with by now.
What's going on is the evaporator-- the coil behind the back wall inside the fridge-- is leaking. It's a manufacturing defect and Sub-Zero was replacing them at either no-charge or a labor-only rate. I think it depended on serial number. You should call Sub-Zero and ask for them to replace the evaporator 100% at their expense. It's worth asking for-- if you don't ask, you don't get! ;)
As for the suction, that's because of the warmer temperatures inside the compartment. The suction was created by the refrigerated compartment rapidly cooling down the warm air that was let in when the door was opened. When the refrigeration system is repaired, the much-loved suction effect will return.
... What's more? I saw water leak at top left foot at outside. Leak stop when I shut off the water feed to ice maker.
that may be another problem ...
If the leak stops when you shut off the water, then you probably need to replace the water solenoid valve. But you have way bigger problems than this!
Dear all, response is fast and useful! Have arranged some subzero folk on site. Good to get this first opinion.
Just in case, I need to absorb all cost,.....what is the part and labor cost I should expect for the evaporator replacement?...including recharge.
Please also help if anyone can explain " I saw water leak at top left foot at outside. Leak stop when I shut off the water feed to ice maker."
The repairman said it is the evaporator leak and just replacing it part and labor is about 800.
He suggested that the evaporator, compressor and heat exchanger should be replaced. Parts and labor is about 1600. He explained that as the leak has been there for a long time, there could be moisture in the system that after evaporator replacement and recharge, the moisture stay in the sealed system may lead to other troubles.
Is the price reasonable? And is his recommendation make sense?
Also he said it uses R12. Is it?
Seems high. He's right a out the moisture but that should be assumed for any sealed system repair. Call SZ and see if they'll cover any of the parts.
Your data plate will tell you what refrigerant in the system is....My book by model number indicates R-12......$ 800.00 for the evaporator job is at the high end of price range , all depends where you live...$500.00 for this repair in this neck of the woods :thumbsup: .....I would like sell the customer the whole job but if done right, you can get away with just the evaporator and 7.0 oz. charge with R12 ( or go R-416A replacement ) .......Or change the evaporator and the compressor to an R-134A system.....about $1000.00......VS....say in the neighborhood of $5000 to ?? $$$ :unsure: the cost of a new unit.... Ditto on asking Sub-O to replace the evaporator but at 21 years :unsure: .......... will not hurt to ask, good customer relations.
