Whirlpool Duet Washer Tub disassembly WFW9400SW01
14 replies to this topic
#1 amkcl1
amkcl1
  • 11 posts
Posted 20 May 2011 - 07:24 AM
Assuming the tub is removed from the cabinet, what are the proper procedures to disassemble the tub?
#2 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 701 posts
  • Flavorite Brew:Coffee
Posted 20 May 2011 - 08:27 AM
With a marker of some sort, mark on the outer tub, both front and rear sides where the silver clips are clipped on. Then start popping the clips off with a flatbade screwdriver. With the clips all off, the two halves will separate. The inner basket will stay on the rear tub if you still have the pulley attached.
Why are you taking it apart?
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#3 amkcl1
amkcl1
  • 11 posts
Posted 21 May 2011 - 06:58 AM
It's making the "bad bearing" roar during the spin cycle.
#4 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 701 posts
Posted 21 May 2011 - 07:45 AM
Replace the rear outer tub and the inner stainless basket as well or you will have a leak or a ruined bearing again. Don't forget to put a new tub gasket on as well. There's nothing worse than putting everything together and having the tub seam leak!
#5 amkcl1
amkcl1
  • 11 posts
Posted 21 May 2011 - 10:53 AM
I have separated the tub halves. I assume that in order to remove the basket from the rear tub I should remove the pulley wheel from the tub. However the large bolt holding in the wheel is not moving. Any advice on how to separate the basket from the tub is greatly appreciated.
#6 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 701 posts
Posted 21 May 2011 - 11:04 AM
Wedge a screwdriver or 2 between the back of the tub the spokes of the pulley. Then it's just brute force to get it off. Don't worry about cracking the rear tub section as you will be replacing it anyway.
#7 amkcl1
amkcl1
  • 11 posts
Posted 21 May 2011 - 01:11 PM
Success!
Thanks!
#8 amkcl1
amkcl1
  • 11 posts
Posted 22 May 2011 - 06:15 PM
I have observed the following: The spindle on the basket has light rust, but looks ok otherwise. The spider supporting the basket is intact, but is covered with what looks like a mixture of dried soap and fabric bits. The rear of the tub half looks ok, the bearing there spins ok. Theres light rust on the metal housing under where the belt wheel would be. Looking into the inside of the rear tub half, the bearing there is rusty, was binding but spun more freely with some cleaning.
I am guessing from this that moisture has somehow found its way behind the basket and into the spindle/bearing area, causing the bearing to rust. if so, then the bearing is not the root of the problem. Any comments on diagnosing this is greatly appreciated.
#9 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 701 posts
Posted 22 May 2011 - 06:48 PM
Replace the inner basket which comes with the shaft and replace the outer rear tub which contains the bearing. Both parts should still be under warranty. Do not just replace the bearing, it will leak again. Even though the shaft looks good, it will be slightly worn from the bearing running on it.
#10 amkcl1
amkcl1
  • 11 posts
Posted 23 May 2011 - 07:33 AM
Whirlpool tells me that all warranties on this machine are expired (purchased 2008).
#11 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 23 May 2011 - 07:48 AM
The warranty for this model:
ONE YEAR LIMITED WARRANTY
For one year from the date of purchase, when this major appliance is operated and maintained according to instructions attached to or
furnished with the product, Whirlpool Corporation or Whirlpool Canada LP (hereafter “Whirlpool”) will pay for Factory Specified Parts
and repair labor to correct defects in materials or workmanship. Service must be provided by a Whirlpool designated service company.
This limited warranty applies only when the major appliance is used in the country in which it was purchased.
Edited by RegUS_PatOff, 23 May 2011 - 08:43 AM.
#12 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 701 posts
Posted 23 May 2011 - 08:13 AM
Sorry - my mistake. I'm in Canada - the warranties might be different here. Most of the tub bearings I've done had the inner and outer basket still under some limited warranty.
#13 RegUS_PatOff
  • 33,588 posts
Posted 23 May 2011 - 08:45 AM
hhmm .. ALL of the Whirlpool Duet WFW9200 / WFW9400's only show a ONE YEAR WARRANTY
all link to Kitchenaid / Canada:
http://www.kitchenai...208183052-W.pdf
for the Whirlpool Duet GHW's
ONE-YEAR FULL WARRANTY (ALL parts & labor)
and the folowing parts:
SECOND YEAR LIMITED WARRANTY ON ALL ELECTRONIC CONTROL BOARDS
SECOND THROUGH FIFTH YEAR LIMITED WARRANTY ON PORCELAIN OR POWDER TOP, DRIVE SYSTEM BELT AND PULLEYS
SECOND THROUGH TENTH YEAR LI MITED WARRANTY ON OUTER TUB
LIFETIME LIMITED WARRANTY ON STAINLESS STEEL WASH DRUM
#14 amkcl1
amkcl1
  • 11 posts
Posted 01 June 2011 - 10:24 AM
When re-assembling the tub/basket/motor, how do I know when the large bolt securing the drive-belt wheel to the tube/basket assembly is tight enough? It seems to loosen after a running a load of wash.
Thanks!
#15 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,015 posts
Posted 01 June 2011 - 01:02 PM
Topics merged.
You have 5 topics going for the same problem. I've merged the two most recent one. Next time, we squeeze your nutz in a vice..Posted Image
