Sign in to follow this
Followers 0
Enrique
Appliance connection HELP!
6 posts in this topic
post-60902-0-79369100-1305898751_thumb.jpost-60902-0-79369100-1305898751_thumb.jHello,
I just moved in to a apartment which had previously a stack combo washer and dryer, and this area has only one outlet which does not look like the typical 3 phase, it has 4 (see image), my best guess is that this single outlet in this laundry has 220 and 110 combined. I have two separate units (washer and dryer) that I would love to use yet I am in need of a direction if it even exist. what I am wondering if there is out there a outlet that could plug in to the one on the wall that could split the 220 and 110 into two separate outlets (moreless like a "Y"), anybody out there I would appreciate your help, thank.
Enrique
From what I can see in the picture, That is four wire connection, single phase ( not 3 phase ) outlet.... A three wire connection does not have the round terminal on the top...... .......The round 'top' terminal is the GROUND, the two outer vertical terminal are 'L1' and 'L2'.... the bottom 'L' is the neutral terminal ( 'L') designates a 30 amp. breaker at the panel..... A vertical terminal at the bottom and is the size of L1 and L2 is a identifier for a range/50 amp............ you will need a licensed electrician to add a 120 v. a.c. from that 240 outlet....if it was your own home you could possibly do it your self.....BUT in your apartment, if you have an electrical fire , guess who is the guilty party..... :blink: I have not seen a 'Y' to branch 240 and a 120...I have on my service van , an adapter to go from 240 to an 120 outlet... 240 range to 120 for a gas range...
Thank for the reply.
I am wodering if you have ever seen a 4 prong spliter into 3 prong 220 and 110 prong as well : /
You could have the Dryer Cord changed to a 4-wire cord.
Newer National Electrical codes require Dryers with 3-wire cords be changed to a 4-wire cord.
Also 120v Washers should have their own Outlet (w/ appropriate Circuit Breaker)
Is there a regular 120v outlet nearby ?
Otherwise your only option would be to buy a stacked washer / electric dryer.
no 120V near by, I will need to get an extension chord which is cheaper than a washer and dryer : ) , but it seem (after reading all the replies) that I can conver my 3 wire dryer to a four 4 chord as well, thanks!
Followers 0
