LG WM3677HW washer/dryer drain hose replace
4 replies to this topic
#1 ElGator
ElGator
  • 3 posts
Posted 22 May 2011 - 08:53 AM
I have an LG WM3677HW combo washer/dryer; been good machine, never an issue. Problem is that plumber’s helper split the gray drain hose while moving it, and now the hose has to be replaced. Hose does not just simply attach to an outlet on the back of the machine (that would be too easy), it goes into the back of the machine at an upward angle. I did find a diagram of the machine and the external drain hose is part of an internal hose assembly. I Can I replace just the drain hose, or does the whole drain hose assembly have to be replaced? How do I access this? Thanks…
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 22 May 2011 - 12:54 PM
# F435 ?
http://www.repaircli...R=154&N=1268100
#3 ElGator
ElGator
  • 3 posts
Posted 22 May 2011 - 02:29 PM
Thanks very much, I ordered the part. Any idea how it's accessed?
#4 john63
john63
    Dean of LG Appliantology
  • 2,212 posts
Posted 22 May 2011 - 02:55 PM
A somewhat big job.
Need to remove:
Top cover
Front control panel
Front of washer.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#5 ElGator
ElGator
  • 3 posts
Posted 28 May 2011 - 08:10 AM
OK, job is done; replacing the drain hose only is actually VERY easy - took all of about three minutes. I ordered the F435 hose above and that was the right part, it mounts just inside the back cover and is replaced from the top. Take out the lower screw on each of the two plastic "latches" on the upper back. Slide the top towards the back (take out the dispenser tray and hit it with the palm of your had to get it started). Remove the top and you'll see where the hose connects just inside on the back. With pair of small channel locks or big pliers to relieve the tension, slide the hose clamp up and off the hose. Remove old hose, install new hose, reposition hose clap, put top back on; you're done!
