GE WSSH300 Spacemaker Front Load Washer
2 replies to this topic
#1 nbaibos
nbaibos
  • 1 posts
Posted 22 May 2011 - 03:39 PM
I am trying to clean a clogged filter that is attached to the drum... sounds like the issues my washer is having is due to this being clogged. How do I remove the front of the washer to reach it?
Thanks!
  • 24,360 posts
Posted 22 May 2011 - 03:59 PM
On your washer, that bottom panel comes off if you remove two screws at the very bottom-- cheek to the floor, you'll see 'em. The pump clean out is in there. No filter, per se. Make sure the drum is empty cuz when you open that pump cleanout, water will come gushing out!
#3 RegUS_PatOff
  • 30,291 posts
Posted 22 May 2011 - 04:09 PM
may need to prop up front of Washer with a piece of 2x4 wood.
Pull the panel down and out
