DD603 Fisher Paykel dishdrawer
1 reply to this topic
#1 pete
pete
  • 1 posts
Posted 22 May 2011 - 07:23 PM
DD603 has new top lid and still does not seal fully at top right front. Drawer locks but leaks over control panel. How do I check operation of pull down motors with drawer out??
Pete
#2 DADoESTX
DADoESTX
    Kohai
  • 260 posts
  • Flavorite Brew:Iced tea with a spike of earl grey
Posted 22 May 2011 - 11:11 PM
Diagnostic Mode.
With Power off, press/hold Keylock, then press Start/Pause at the same time for 5 seconds. Release the buttons when it powers-on.
Press Power once.
LCD says "HO" (hardware output), and/or all cycle selection LEDS are on.
Press Start/Pause repeatedly (three times from the start) until LCD says "Ld" and/or Delicate & Rinse cycles are lit. *Various components/functions can be tested by pressing Start/Pause to select.
Press Keylock to operate the selected function. Lid motors will operate for 10 seconds to lower or raise each time Keylock is pressed.
Press Power to exit when done.
*Er or Delicate - heating element relay -- DO NOT leave it on for more than a few seconds without water in the tub or the temp high-limit fuse on it may blow
How to enter diagnostic mode in a Fisher-Paykel DD603 dishdrawer
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 23 May 2011 - 08:22 PM
Diagnostic Mode.
Press Power once.
LCD says "HO" (hardware output), and/or all cycle...
Read Full Entry →
