Troubleshoot modern appliances with confidenceā€¦
RivaGirl
Frigidaire Gallery PLRS 267ZAB6 side by side refrigerator freezing food
6 posts in this topic
Freezing fridge.
Been advised air damper and cold control may be the culprit.
How do I find and test the cold control?
I'll buy my new part through your site- thanks for hosting this forum!
model number on prev post PLRS 267ZAB6
OK people - if the fridge is freezing, it could be the Damper.
Fridgidaire recommends seeing if that little hole going between fridge and freezer is frozen over (it's in back of meat drawer on our side by side). If there are signs of ice, it could get stuck in the fully open position (regardless of what you have it set at). If that internal auto adjuster gets stuck and lets cold air in all the time. the fridge will freeze. Their solution - a tool I use everyday. Defrost that hole area with a hairdryer.
To trouble shoot this easily before busting out the hairdryer, you can use a mirror to look for ice or use your finger to see how much cold air seeps in when the meat drawer is set to "coldest" vs "warmer."
Hey, RivaGirl, so you fixed it?
If I remember this unit, the lower air return has a plastic flap/door that stops air flow..The top air flow is controlled by the motorized damper door..........If the lower flapper is stuck in the 'open' position, lower temps in the fresh food section... the fresh food cold control , controls the damper assembly..... Find your tech sheet, possibly in the toe grill or the control console....It will tell you how to test the damper assy.....service data sheet 240389604 or publication # 5995365466.....P.S. :wallbash: cannot find that publication at the friggy site
Edited by certified tech group 51
...publication # 5995365466
from the friggy site:
1) 240389604 (or 240389607) mentions Defrost diagnostics, but not Damper operation
2) 5995365466 is the Parts Manual (no diag info)
