Whirlpool ED5HVAXVLOO side by side refrigerator with ADC, getting into defrost mode
2 replies to this topic
#1 vin-tech
vin-tech
    Ikkō-ikki
  • 47 posts
Posted 23 May 2011 - 06:53 PM
Looking at blow up of this sxs fridge, it has adc controls--part number w10135900.(Am i right--????)
How does one takes this fridge in to defrost mode.
thanks,
victor
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 23 May 2011 - 07:08 PM
yes
http://www.repaircli...R=154&N=1450346
do one of the following options, then do "ENTER TEST MODE"
OPTION #1 (BI-METAL CLOSED)
1) POWER OFF TO REFRIGERATOR FOR AT LEAST 30 SECONDS
2) THERMOSTAT OFF
3) POWER ON TO REFRIGERATOR
OPTION #2 (BI-METAL CLOSED)
1) THERMOSTAT OFF 15 SECONDS
2) THERMOSTAT ON 5 SECONDS
(REPEAT STEPS 1 & 2 TWO MORE TIMES)
3) THERMOSTAT OFF
then:
ENTER TEST MODE
IN 3-8 SECONDS, CONTROL WILL TURN ON DEFROST HEATER.
DEFROST HEATER WILL TURN ON FOR 21 MINUTES OR UNTIL BI-METAL OPENS.
TO TERMINATE TEST EARLY, REMOVE POWER FROM REFRIGERATOR.
NOTE: IF OPTION #2 DOES NOT WORK, TRY OPTION #1 BEFORE REPLACING CONTROL
ALWAYS CHECK CONNECTIONS BEFORE REPLACING CONTROL
HELPFUL HINT: UPON ENTERING TEST MODE, A RELAY TURNS OFF THE COMPRESSOR AND TURNS ON THE DEFROST TIMER.
LISTEN FOR THE RELAY TO CLICK. IF RELAY CLICKS ONCE UPON ENTERING TEST MODE, CHECK FOR DEFROST HEAT.
IF RELAY CLICKS TWICE, CHECK FOR BI-METAL OPEN.
WARNING: IF BI-METAL IS BY-PASSED FOR TESTING, DO NOT OVERHEAT EVAPORATOR AREA
#3 vin-tech
vin-tech
    Ikkō-ikki
  • 47 posts
Posted 24 May 2011 - 07:43 AM
THANK YOU SO MUCH
VICTOR
How to enter defrost mode in a Whirlpool side-by-side refrigerator with electronic defrost
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 23 May 2011 - 09:11 PM
Source: Whirlpool ED5HVAXVLOO side by side refrigerator with ADC, getting into defrost mode
Read Full Entry →
