Sign in to follow this
Followers 0
jwales
Amana LEA30AW electric dryer
3 posts in this topic
Dryer "runs" but will not heat up. I have followed all the helpful tips from here & repair clinic. Heating elemnet has continuity. What I beleive to be the hi limit and cycling thermostats have continuity (i cant tell which is which). The thermal fuse does not have continuity and the wire on one end of it got hot, is chared with melting on orange coating. This short wire connects to one of the thermostats that is mounted to the heating element frame. So I need to replace the thermal fuse.....should I be worried about something else that caused this to fail??? Or can i just slap a new one on??? I also notice on the power cord where it connects to the dryer, one of the positive wires had a little charring at the connection. I think I will replace that as well.
Your response is appreciated oh great one.
... the wire on one end of it got hot, is chared with melting on orange coating.
... should I be worried about something else that caused this to fail?.
1) bad / dirty / corroded / over-heated / connectors can over-heat again
2) Dryer Vent system
http://www.repairclinic.com/referral.asp?R=154&N=915698
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
Replaced the thermal fuse and the 10 gauge wire that was burnt and everything works just fine.
Thanks!
Followers 0
