Electrolux Range EW30IA65JSA
4 replies to this topic
#1 avan
avan
  • 3 posts
Posted 27 May 2011 - 07:13 PM
I took the door off of my Electrolux range in order to move it more easily. I cannot figure out to get the door back on. The directions are no help. How should I approach the range with door and how do I maneuver the hinges so that they slide in between the two rungs in the slots? Please help. thank you.
    Shōgun
  • Master Samurai Tech
  • 30,577 posts
Posted 27 May 2011 - 11:30 PM
This awwta git it for you...
#3 avan
avan
  • 3 posts
Posted 28 May 2011 - 06:15 AM
I put the lock in the open position to remove the door and it is still in this position. The trouble I am having is getting the hinges to engage in the crevices. They won't go in all the way. There must be an angle or a nudge to engage that I am missing. The door weighs 70 pounds, so this is not easy. Thank you.
#4 avan
avan
  • 3 posts
Posted 28 May 2011 - 06:20 AM
To be sure I understand, does the picture show the way the lock and hinge are positioned in order to return the door to the range?
    Shōgun
  • 30,577 posts
Posted 28 May 2011 - 01:45 PM
Yes.
It can be tricky to get these heavy doors back on, especially if one of the hinge tongues that stick in the door got bent slightly. Has to line up perfectly. May need to get a second person to help.
