Maytag MER5555QCW oven (bake and broil) doesn't work
#1
Posted 27 May 2011 - 10:25 PM
#2
Posted 27 May 2011 - 11:51 PM
You'll find it affixed to the back panel, under the center piece.
Here's the replacement... http://www.repaircli...mber=MER5555QCW
#3
Posted 28 May 2011 - 01:51 AM
have you used Self-Clean lately ?
#4
Posted 28 May 2011 - 08:55 PM
I suspected it might be the Hi Limit Switch problem. Just not sure how to check and confirm that's the problem. Do I have to replace it or it can be reset as you suggested. How to reset?
Really appreciate your expertise and help.
#5
Posted 28 May 2011 - 08:57 PM
normally that one is re-settable... (press red button)
#6
Posted 30 May 2011 - 08:49 PM
#7
Posted 30 May 2011 - 09:01 PM
#8
Posted 30 May 2011 - 09:05 PM
Oven High Limit
NOTE: Requires removal of oven from installation position.
1. Turn off power to unit.
2. Remove lower rear access panel.
#9
Posted 31 May 2011 - 07:53 AM
#10
Posted 31 May 2011 - 08:19 AM
... do I have to replace the control board?
yes, bad Controller, IF you have 240v at the Controller Board from the big RED wire to the big BLACK wire
When the Bake Element "exploded", it may have taken out a Relay or two, and part of the Controller printed circuit.
http://www.repaircli...R=154&N=1795917
#11
Posted 31 May 2011 - 08:48 AM
#12
Posted 31 May 2011 - 09:08 AM
you said you don't have one ...After replacing the control panel, do I still need to reset the Hi Limit Switch (thermstat)?
DO you have 240v at the Controller Board from the big RED wire to the big BLACK wire
