Fisher & Paykel washer GWL10US
#1
Posted 28 May 2011 - 01:18 PM
#2
Posted 29 May 2011 - 08:14 AM
Changing the pump is easy. No tools needed. Get access under the machine. Remove the wires from the pump. Find a plastic latch on the pump mounting bracket. Hold the latch released and rotate the entire pump counterclockwise to detach it from the bracket. Lubricate the rubber seal face around the impeller with liquid detergent to facilitate rotating it into place when remounting.
GWL10 pump is specific to that model, Part Number 420324P (or 420324P-D). SearsPartsDirect.com or FisherPaykelParts.net (compare prices at both sources, and/or search for other sources).
Edited by DADoESTX, 29 May 2011 - 08:20 AM.
#3
Posted 29 May 2011 - 09:38 AM
#4
Posted 29 May 2011 - 11:35 AM
#5
Posted 29 May 2011 - 01:26 PM
#6
Posted 30 May 2011 - 12:15 AM
SearsPartsDirect has carried F&P parts for several years ... at least 5 years. I think I've mentioned that in previous posts, and I think others have mentioned it as well.
I believe F&P does sell parts and accessories directly but I don't know how the prices compare.
#7
Posted 03 June 2011 - 10:45 PM
#8
Posted 06 June 2011 - 08:50 PM
#9
Posted 05 March 2013 - 11:04 PM
I have this washer (great machine, by the way).
I'm trying to convert to a laundry to landscape setup, but that requires I make some mods to the drain tube on the back of the washer. There is what appears to be a mounting adapter on on the back that I'm assuming allows me to change the tubing type (from "corrugated" to a smooth-wall but I can't figure out how to get that panel off (without breaking things). Any ideas?
Shawn
#10
Posted 06 March 2013 - 11:01 PM
the drain hose is fixed dont muck around with it
im not sure what you mean by landscape setup ??
#11
Posted 07 March 2013 - 05:53 PM
i think he means he wants to pump his wash water out into his landscaping around his house
#12
Posted 13 March 2013 - 07:58 PM
Parts through F&P are far cheaper than S***s.
Call 888 936-7872. Choose option 4 to talk to a rep. Order them over the phone.
You can, however, use S***s' lookup system to see the diagrams. That way you'll know what to ask for... if your phone, tablet or laptop doesn't choke on the massively bloated S***s website.
And if you can chisel your way down through all the popups trying to get to you talk to one of their salesmen.
Edited by ScottsApplianceRepar, 13 March 2013 - 07:59 PM.
Joe Customer: "Because we have to pay you to leave."
