romanof
Maytag LA412 Washer
16 posts in this topic
Back with another repair of my dependable care Maytag washer. Washer started leaking today and after investigating source and going through the repair manuals you all provided back in April, looks like stem seal is the cause. I want to be sure what to order and I know I need the spaner wrench too. Just want to be sure I did my due diligence on the source of the leak and know what to purchase from you all.
Thanks.
What I'd like to know is should I buy the tub spin seal kit or is there something else I need? What's the part number on appliantology please?
this link should do ya
yo stuff
From what I've read I'll need the grease too. Is that a correct?
Where did you read that?
I don't recall using any grease on this job but it's been a couple years.
Somewhere it said about using a lubricant for the bearing. May be wrong on this though.
No lubricant DO NOT use lubricant on the bearing sleeve
you can apply a small amount of dish soap on the outside rubber portion
to make it easier to insert it into the metal outer tub as well as
a little on the bottom inside diameter of the boot to assist sliding it down on the inside lip of the outer tub.
you dont want any lubricant to get on the bearing sleeve, housing, or the face of the bakelite seals and should make sure
they are clean and dry using a paper towel before installing. sometimes some grease gets on the face of the seals when they package the part. the boot seal does have grease inside that gets squished out sometimes.
Thanks for the advice on NO LUBRICANT. I 'll be sure to follow your directions for the install. Transferring $$ to my paypal account so I can order the parts.
Replacement parts and spanner wrench delivered yesterday from Repair Clinic and I've successfully removed the inner tub. But have a problem getting the mount stem off. After removing the Allen screw and using the spanner wrench and hammer turning clockwise I just seem to be turning the transmission rather than loosening the mount. See photo - Any suggestions?
post-59975-0-13191300-1307216362_thumb.j
Finally got the mount stem off. Disregard previous request for suggestions.
Outer tub and bearing now removed. I'm on step 22 of the text instructions 'Samurai Appliance Repair Man" attached on 5-29-2011. What's the "metal sleeve collar on the transmission shaft? I also have the manuals I got from you all some time ago and can't find a reference to metal sleeve collar. Gonna keep workin here. Need some clean cloths.
post-59975-0-84686500-1307227424_thumb.j
The new mounting stem seal came with a metal sleeve but it doesn't fit over the trans shaft. Perhaps a difference in trans shaft than what it's thought to be? With tub seal firmly in place in outer tub it fits snuggly over trans shaft without wobble.
post-59975-0-62890500-1307230739_thumb.j
All's well. Put everything back together, then did some more research on makin sure I was puttin the tub cover gasket and band back on right. Found out I didn't do my homework on the "metal sleeve". It didn't come off cause it's more or less welded to the tranny shaft. Got out the butane torch I use for sweatin copper water pipe, heated the thing up and chisseled is out, being careful not to damage the tranny shaft. Got it off in pieces. Then used some very, very fine sand paper to clean the tranny shaft and put the new "metal sleve" on. Wife home from work now but got to test the machine in spin cyle (no vibration or unbalanced innner tub). Gonna spend time with some more brew and the wife now - nice cool night out in the back yard.
Not much more to do but get the drum cover tightened down, reconnect the left side water tube, fasten down the top cover and do a test wash. More to follow.
Want to say, wouldn't have, couldn't have, done this without you guys. It wasn't that hard of a job and I'm sure I saved 100"s over havin a repair guy come over and do this. Thanks so much.
Here's what's left of the old sleeve.
post-59975-0-14758400-1307247382_thumb.j
Nice job! Very dramatic removal of the tub bearing. Don't recall ever having to get quite so medieval on one of those beasties but they do like their rust like a sailor like his rum. drunkass.gif
Time well spent and money well saved on this repair. Put the old Maytag through a complete wash, rinse, spin cycle. NO LEAKS!!! Won't be callin the Maytag guy for any other repairs. The dryer's a Maytag too so if it fails me I'll whoop it back into shape. :cheers:
post-59975-0-76864600-1307292431_thumb.j
