Dave947
Kenmore Front Load Washer, Model # 417.42142100
15 posts in this topic
My Kenmore/ Sears front load energy star washer stopped agitating/spinning yesterday. When I run it the water drains but, as I said, no agitation (other than my own). I've got it pulled out, unplugged, ready to trouble shoot... where do I start?
Remove the front panel and see if the belt is broken.
The belt is not broken.
Does the Tub move at all on it's own ?
Nope, not as of yesterday.
Okay, I got to step 2 on the flow chart; the resistance between 1 and 2 was good but 2-3, and 1-3 was shot. On the flow chart you provided the result is a defective motor. On the tech sheet for the washer it recommends replacing the speed control board. Any thoughts?
Should have mentioned that I checked the resistance at the molex as well and there seems to be one open plug. I also pulled the belt off and when I plugged the washer back up the motor did rotate. Am I just using my voltmeter wrong...?
ALSO-- when I put the belt back, plugged it back in, and gave it a spin a few times manually from the back, the spin cycle kicked in. This leads me to believe that it's not the motor but perhaps the speed control board after all. Any thoughts on this??
maybe ... or a bad connection somewhere
test again
also, what reading did you get "1-3 was shot" ?
I'm getting a little over 1ohms for 1-2 and nothing for 2-3 and 1-3. Just checked it again.
Finally, per the flowchart, I tested the volts between pin 5 of the 6 pin plug and the following pins of the 10 pin plug: 1,2,6,9,10.
Here are my readings:
1- 120v
2- nothing
6- nothing
9-nothing
10-120v
This, of course, does not match the outcomes for diagnoses per the flowchart.
Samurai, help a brother out... I priced out a new motor ($150) and a new speed control board ($151) from Sears. What is your best guess?
Just put in the speed control board from repairclinic.com and it has not fixed the problem. Am I looking at a new motor at this point and (have I possibly ruined this new speed control board?) Could the wire harnesses be bad between the motor and the control board?
New motor.
New speed control board.
No change, still not working....
Any other ideas at this point???
