Whirlpool Duet Steam F35 errors
4 replies to this topic
#1 roberto
roberto
    Yamabushi
  • 79 posts
  • Flavorite Brew:Stella Artois
Posted 01 June 2011 - 10:38 AM
We a Duet Steam that will not complete wash cycles and delivers F35 codes. That code seems to relate to the steam process. We did everything the tech sheet recommended. We replaced the Steam control board ( nearly $200!). Anyone have experience with this problem. Anyone know how to test the pressure switch?
Is there a tech manual available?
Much respect. Thanks very much.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 01 June 2011 - 11:09 AM
model number ?
#3 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,918 posts
  • Flavorite Brew:Killians Red
Posted 01 June 2011 - 03:48 PM
That tech sheet is garbage...and whirlpool is aware of it.
F35 is a analog pressure switch failure...i replace at least one of these a week.
if not already doing so, use ONLY HE detergent in the proper doseage after you replace this switch.
#4 roberto
roberto
    Yamabushi
  • 79 posts
Posted 01 June 2011 - 05:40 PM
whirlpool duet steam m# WFW9600TA00 (Sorry forgot to include m#. )
We've the Pressure switch - W10156252 - has be discontinued. Anyone know of correct replacement.?
Thank you.
#5 RegUS_PatOff
  • 33,588 posts
Posted 01 June 2011 - 05:59 PM
... F35 codes. That code seems to relate to the steam process.
F35 ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
1) Check if pressure hose is fi xed correctly.
2) Check if the airtrap is not blocked.
3) Check if the hose is not blocked.
Thank you.
http://appliantology...e-switch-issue/
How to fix Whirlpool Duet steam washer F35 errors
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 01 June 2011 - 09:13 PM
ame='RegUS_PatOff' date='01 June 2011 - 05:59 PM' timestamp='1306969192' post='197724']
If this...
Read Full Entry →
