LG Trom Washing Machine WM0532HW
3 replies to this topic
#1 Bruce M. Floyd
Bruce M. Floyd
  • 4 posts
  • Flavorite Brew:Budweiser
Posted 02 June 2011 - 07:17 AM
I am going to replace the door latch/lock switch on my washer. Are there tricks to removing the front panel to access the switch and are there any precautions while doing so. Any help would be appreciated. Thanks- Bruce M. Floyd
#2 BLTH15
BLTH15
    Kohai
  • Appliantologist
  • 396 posts
Posted 02 June 2011 - 09:23 AM
no need to take front panel off. remove spring that holds gray door boot in place. look around the edge you'll find the spring you pull to stretch. pell back boot remove screws from switch disconnect wires and you're all set.
#3 Bruce M. Floyd
Bruce M. Floyd
  • 4 posts
Posted 03 June 2011 - 08:35 AM
Sublime Master Kohai- Thank you very much for sharing your wisdom with me. I will follow your instruction. Thanks Again- Bruce M. Floyd
#4 Bruce M. Floyd
Bruce M. Floyd
  • 4 posts
Posted 03 June 2011 - 09:01 AM
Sublime Master Kohai- By following your instructions even a grasshopper such as myself was able to have the old switch out and in my hand in under 5 minutes. Thank you again for your wisdom- Bruce M. Floyd
How to replace the door latch assembly in an LG Tromm Washing Machine
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 03 June 2011 - 09:49 AM
no need to take front panel off. remove spring that holds gray door boot in place. look around the edge you'll find the spring you pull to stretch. peel back boot remove screws from switch disconnect wires and you're all...
Read Full Entry →
