Maytag dryer PYG2000AWW propane oder / conversion
5 replies to this topic
#1 jigget
jigget
  • 3 posts
Posted 02 June 2011 - 07:37 PM
had to replace my gas dryer. Bought a used one that was set up for natural gas. Bought a replacement kit to change it over to lp. Now we are smelling propane in and out of the dryer. Checked all the lines with soap for holes and can't find any. The smell keeps getting stronger.
#2 appl.tech.29501
appl.tech.29501
  • 8,025 posts
Posted 02 June 2011 - 08:36 PM
Whats the part # for the conversion get that your purchased?
#3 jigget
jigget
  • 3 posts
Posted 05 June 2011 - 10:33 AM
part # was 63-6766
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 05 June 2011 - 11:56 AM
and did you follow the included directions ?
#5 jigget
jigget
  • 3 posts
Posted 05 June 2011 - 12:56 PM
yes we did. changed the vent also and now we just have a strong odor inside the dryer when running. should the flame kick on and off about every 20-30 seconds??
#6 RegUS_PatOff
  • 33,588 posts
Posted 05 June 2011 - 01:13 PM
... should the flame kick on and off about every 20-30 seconds??
no
Try running an empty load with the Vent disconnected.
also,Dryer must be fully assembled for correct air-flow
If you could check the temperature at the Dryer Vent:
and check your Venting System
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
