Kenmore washer 417.44052401 won't spin
11 replies to this topic
#1 brianl0646
brianl0646
  • 13 posts
Posted 03 June 2011 - 12:06 PM
I have a Kenmore front load washer model 417.44052401, and all of a sudden it won't spin anymore. It does the rest of the cycle fine but when it comes to the spin part it makes the noise like it should be spinning but no spin. I unplugged it, took everything out, just tried a spin cycle by itself, but no luck. Any ideas?
Brian
#2 RegUS_PatOff
  • 30,262 posts
Posted 03 June 2011 - 01:40 PM
It won't Spin until the water gets Pumped out.
Does the Pump work OK ?
Are there any Error Codes / flashing Lights ?
#3 brianl0646
brianl0646
  • 13 posts
Posted 10 June 2011 - 11:39 PM
Water gets pumped out OK, and I don't see any flashing lights on the front. I checked the hose on the pressure switch as well.
Brian
#4 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 10 June 2011 - 11:54 PM
Put your washer in the spin cycle again. Let it go for about a minute then unplug the washer. If you can open the door right away then you need a new door latch assembly. If the door stays locked then you have a different problem.
Edited by SANTA, 10 June 2011 - 11:56 PM.
#5 brianl0646
brianl0646
  • 13 posts
Posted 14 July 2011 - 07:45 PM
I can stop the machine at any time and open up the door. In the past once it stated the cycle you could not open the door till the very end. Now it does not lock me out like it used to. No matter where in the cycle it is I can hit stop then open the door. So I need a door latch assembly then? Is this a hard repair?
Brian
#6 RegUS_PatOff
  • 30,262 posts
Posted 14 July 2011 - 08:49 PM
http://www.repaircli...R=154&N=1531974
 then watch video
#7 brianl0646
brianl0646
  • 13 posts
Posted 14 July 2011 - 09:00 PM
Thanks, looks easy. The link you gave me is for the correct part?
Brian
#8 RegUS_PatOff
  • 30,262 posts
Posted 14 July 2011 - 09:05 PM
yes
#9 brianl0646
brianl0646
  • 13 posts
Posted 14 July 2011 - 09:12 PM
Thanks, got it ordered, now hopefully my wife will quit threatening to call a repairman.
Brian
#10 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 14 July 2011 - 09:45 PM
Your wife has alot of patience.
#11 brianl0646
brianl0646
  • 13 posts
Posted 28 July 2011 - 11:24 AM
Got the part, installed in less then 5 minutes, washer works great! If only everything could be so easy. Thanks for all your help.
Brian
#12 RegUS_PatOff
  • 30,262 posts
Posted 28 July 2011 - 01:09 PM
:cheers: :cheers: :cheers:
